Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Casetronic C134 & Epia MII
    Jan 2004
    NYC
    whats up guys, just wondering if anyone tried to fit a MII into C134.
    Im about to place my order for my parts. I was going to make a case that same size. This would save me alot of time - but on the C134 specs it says it only fits a M series MB. I was planning on getting the MII because of the PMCIA slot[sound card]
    Do you guys think it would fit without the cover??
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I don't think it fits in a C134... maybe if the case were modified. The C138 is listed on Logic supply as compatible. However the C138 is twice as high as the C134.
    This should be useful:
    http://www.logic-supply.com/popup_casematrix.php
    (remove '-' between logic & supply)
    Low Bitrate Hacksaw's Avatar
    Nov 2003
    Southwest UK
    I contacted Mini-ITX about this, the answers a no, unless you want to hack it.
    (1) The MII's card slots are too high to allow the use of a DVD drive.
    (2) If the card readers were removed the back plate is completely different, the C134 apparently having the back plate built into it rather than the large hole for your own.
    The C138 is nice, it's what I'm using at the moment, but as said it is a fair bit bigger.
    2000 Vauxhall Vectra SXi
    EPIA M12000 / 256MB RAM
    PW-120 + ITPS
    Slot Loading CDRW/DVD
    30GB 2.5in HD
    Lilliput 7" VGA + Touchscreen
    GPS Nav
    Installation progress {+++++++} (Installed! :) )
    Jan 2004
    NYC
    Ahh that sucks, it can never be easy
    Im wondering If i can just remove the c134 backplate, use no backplate.
    But now I wont have a room for a DVD drive!
    SO its either dont have a DVD drive,but no custom case building
    or
    have a DVD drive, but no card slots and use up another USB slot for a sound card....do they even make a USB soundcard???
    Nov 2003
    Southwest UK
    Yeah, it's a bummer as I have a spare din slot just waiting to have one.
    Theres this external box (amongst others):
    http://www.soundblaster.com/products/extigy/
    PW-120 + ITPS
    30GB 2.5in HD
    GPS Nav
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    Quote Originally Posted by camsgs3
    Order your parts
    I did this mod about 6 months ago and it works great. I'll post the pics up here tomorrow when I get home. There was no room for the HD unless you don't need a CD drive, so I used a CFII drive mounted in the front under a DVD drive. My requirement was a PCMCIA slot for my 1XRTT modem. I also went with a 120W snap in power supply and put the ITPS in place of the PW-60 that came with the case. Everything fits in the Stang’s factory 1-din head unit slot.
    NOS
    Jan 2004
    NYC
    Quote Originally Posted by NOS TANG
    Order your parts
    NOS
    YES...please post some pics
    SO your not using a HD? I need a HD. As for the DVD, can it fit going sideways like from side to side, not from front to back, i dont mind dremmeling a DVD slot on the side of the case. How come you didnt use the Mortex 60w that came with the case?
    Ohh yea what about the back of the case, any problems with the port cover
    Mar 2004
    OH USA
    I'm using a 4 Gig CF II microdrive in place of the standard hard drive. I made it removable from the front of the case. There is plenty of room for a slim CDROM/DVD drive to fit in the stock position with the MII card bus board. Problem was the MII card bus board sits directly where 2.5 HD would be mounted in the C134 case. So I opted to go with the CF II drive for the OS and a USB drive for music and storage. This way I can also change OS from XP to Linux by just swapping out the CFII cards turning on the key. The MII will boot from USB also if you want to go that way.
    I ditched the PW-60 power supply to make room for the CFII adapter and the ITPS unit to fit in the case. There might be room to put a 2.5" HD in place of the PW-60 also, I will check that for ya. I think the front USB / audio ports conflicted with that design if I recall. Plus that 120W snap in board fits perfect with the card bus, and is just too clean of an install to pass up.
    Back of the case.... Hacked it out with a jigsaw and dremel. Made a nice new port cover out of thin plastic to hide the hack job. Looks good from the outside. I have designed a case in AutoCAD that fits all the mini itx boards using a 1-din design, currently just looking for a manufacture to stamp them out for me.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    One thing 'bout the CaseTronics, they're 10" deep.. so double check your dash for clearence (plus adapters --USB, etc).
    •Micke
    Mar 2004
    OH USA
    Quote Originally Posted by grepzen
    Very good point
    And if you shorten the case to 8" or less, the CDROM drive will hit the card bus board on a MII. Might work ok with the non-card bus boards.
  1. WTB: Carnetix P-1260, Via Epia M10000, CaseTronic Travla C134
    By swissRv in forum Classified Archive
    Last Post: 08-16-2004, 01:00 PM
  2. Temp monitor program for Epia MII 1k0
    By samc in forum Software & Software Development
    Last Post: 05-14-2004, 06:41 PM
  3. Opus PSU for Casetronic C134
    By aethernaut in forum Power Supplies
    Last Post: 02-25-2004, 01:19 AM
  4. DC-DC Converter for C134 EPIA M1000 Nehmiah
    By entr0py in forum Power Supplies
    Last Post: 02-24-2004, 09:22 PM
  5. Using Sealed Lead Acid battery with Casetronic C134
    By MikeH in forum Power Supplies
    Last Post: 11-21-2003, 09:27 PM
