Results 1 to 10 of 11
Thread: BEWARE: Epia V8000 & Opus 90W combination
    Jun 2004
    Upstate New York
    Exclamation BEWARE: Epia V8000 & Opus 90W combination
    Anyone considering purchasing the Epia V8000 should read this. The aggravation caused by this is certainly not worth saving a few bucks by buying the V8000.
    I am currently having an issue with my Opus 90W and my Epia V8000. It seems that sometimes the PC won't boot, everything turns on, but I get no BIOS beep code and no VGA, so the motherboard is hanging up as soon as it turns on. After pulling my hair out for weeks within the forum here, the manuals for both the Opus and the motherboard, and trying to troubleshoot the problem on my own I finally send an e-mail to Opussoultions.com. Below is the response that I got:
    If it boots up sometimes it means you placed the power-on connector in the correct direction. The Epia-V8000 motherboard has a compatibility issue with our power supplies. Some power supplies work and others don't, it's all based on a difference between the startup time of the 3.3V, 5V and 12V rails. Unfortunately Via does not wish to cooperate with us and try to resolve this issue, which could be done by a BIOS update.
    If you would send us the motherboard with the power supply we can make them work together for you, it will require some hardware changes in the power supply.
    We apologize for the inconvenience.
    Rafal Krawczyk
    Opus Solutions Inc.
    26941 Cabot Rd. S#120
    Laguna Hills, CA 92653
    Tel: (949)305-4200 Ext.225
    rafal@opussolutions.com
    I replied with some questions that I will post answers to as soon as I get them. The questions are as follows:
    How long would I be without the unit (approximately) and would I be better off upgrading the motherboard to an Epia MII 12000? Are there any compatibility issues with the MII 12000 motherboard that you know of? If I send in the PSU and decide later on to upgrade the motherboard will there be issues with the new motherboard? Will I be charged for the changes to the PSU and if so how much?
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    You'll be without your hardware for at least a month, probably more.
    Jun 2004
    Upstate New York
    And the response from Opus:
    Only the Epia-8000 and Epia-CL have this problem.
    All the other Epia boards work flawlessly...
    No, there wouldn't be any issues later on. The problem is the timing margin
    that Via allows in these two motherboards. All the newer Epia motherboards
    have this problem solved. There are no charges for these changes.
    I have the feeling you're probably right however, money's a bit tight right now so I don't think upgrading the motherboard is much of an option at this point. Guess I'll have to send it in
    Jun 2004
    Upstate New York
    Update
    Sent the package off today to have the modification to the Opus done. Opus says turn around time is 1 day so hopefully I should have it back in a couple weeks. I'll keep you guys updated on Opus's service.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Good to know thanks for the info
    TruckinMP3
    Read the FAQ!
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    My EPIA V8000 runs fine off my OPUS 90w.
    John
    Jun 2004
    Upstate New York
    Update:
    Got my Opus & Motherboard back a couple of weeks ago, tried installing it last week. It's now worse than before and won't boot at all. I've been e-mailing back and forth with tech support at Opus but have gotten no answers yet other than "it worked fine here". Looks like I may end up scrapping the V8000 and move up to an M series board. Apparently this is only an issue with the V and CL series boards. Also it doesn't happen on all V and CL series motherboards, some work fine.
    Jun 2004
    Upstate New York
    So as of today I am officially giving up on the V8000. I just ordered an M10000 and 512MB of DDR266 RAM so that I can again have a working PC in my truck. Guess now I'll have to find a use for the V8000.
    Jul 2004
    Dude, that sucks. Stick it in the classifieds. Someone will buy it from you. It's a good board. Just not with an Opus!
    Elsewhere
    Quote Originally Posted by Jailer
    Reading your thread, I'm inclined to disagree with you that it's the motherboard.
    You sent the board to Opus and they tested it with your power supply and it worked just fine. You also say that sometimes it boots up fine and other times it does nothing.
    I'd be more inclined to think that it's the electrical system in the behicle causing it, as the trained professionals have used your P/S and your motherboard in a lab environment successfully.
    The trick is to determine what the factor is that's causing it to boot up when it does and what's causing it not to boot when it doesn't. That will at least give you something to start looking for.
    Just my two cents.
    How about the Wiki?
  1. Strange Opus 90W problem
    By Jailer in forum Power Supplies
    Last Post: 11-02-2004, 02:16 PM
  2. FS: Opus 90w PSU, EPIA M9000, 256Mb RAM, Morex PSU
    By GingerPrince in forum Classified Archive
    Last Post: 10-07-2004, 07:25 AM
  3. EPIA MII-12000 and Opus 90W
    By voidunknown in forum Power Supplies
    Last Post: 09-02-2004, 05:33 AM
  4. Opus 90w problem
    By sxpert in forum Power Supplies
    Last Post: 07-20-2004, 09:56 AM
  5. EPIA M6000 and Opus PS
    By millec in forum Power Supplies
    Last Post: 01-09-2003, 01:12 PM
