Results 1 to 7 of 7
Thread: Video car problems....
    Feb 2004
    Green Bay, WI
    Video card problems....
    I put in a pci video car last night into my system to test....started the pc and got nothing on the screen....powered of the pc and removed the card and restarted and now nothing is on the screen when the monitor is plugged into the onboard video.....
    What happened????????
    try a different cable, perhaps you damaged it when moving it about.
    try a different card and/or monitor.
    Other than that you may have had a faulty card that has damaged your monitor.
    Feb 2004
    Green Bay, WI
    Failed the mention the card was just working in a different pc yesterday and the monitor works on a different pc also...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    did you disable and uninstall your existing video before setting the new one up?
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Reset the bios values by enabling the 'clrcmos' jumper and putting it back to the default position...
    Feb 2004
    Green Bay, WI
    ok Thanks.....I'll try that when i get home from work.....
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Yeah, the BIOS will be configured for onboard video if it exists. You should disable that before you install the card.
    Quick! To the Popemobile!
  1. Those of you that have used Peal N Seal...
    By Defiler in forum General MP3Car Discussion
    Last Post: 09-22-2004, 09:45 AM
  2. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
  3. Shuttle XPC SS40G - 3D Video problems
    By dekodan in forum General Hardware Discussion
    Last Post: 07-27-2003, 12:42 PM
  4. sv24 video problems again
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 01-06-2003, 10:00 AM
  5. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
