Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 114
Thread: Valentine One Solution!
  1. #21
    Jan 2003
    Ruston, LA
    Quote Originally Posted by 0l33l
    Download CID plugin here. What this does is put an app in the systemtray that monitors and logs calls by having the modem listening for the callerid strings. Also has a record of calls you missed by counting the number of rings.
    Cool, Thanks.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #22
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by frodobaggins
    Cool, Thanks.
    Np. Tell me if it works
  3. #23
    Jan 2003
    Ruston, LA
    I'll have to find a modem first
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #24
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by nickmig
    Chairboy..do you have a v1?
    Nope! If I did, I'd definately love to contribute more, but...
    An early planning step in a project like this might be to scour the web for pinouts on the cable. Maybe there's a V1 service manual that might have it, for instance? If so, might be worth cozying up to your local high end car audio/etc shop who might let you take a gander.
    Chrysler 300 - Fabricating
    http://hallert.net/
  5. #25
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    If it's any help, that looks a lot like the escort, but has a more complex protocol. The escort just uses data acquisition (5V idle, 0V pulses) to control a remote beeper/LED. You can use a DMM to figure out which pins are GND and 12V, then the other 2 pins are data and data ground (probably) or tx/rx but I wouldn't think it's 2-way. Connecting those 2 pins to a scope and turning it on can tell you what the signal is easily, but a DMM would at least show if it's within a safe 5V range for connecting to RS232, then you can try to reverse engineer the data coming from it if it's even compatible.
  6. #26
    Sep 2000
    LA, CA, USA
    Ask and you shall receive
  7. #27
    Aug 2004
    Leawood, Kansas
    sweet! Thanks..I have to go consult with my ee buddy.
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
  8. #28
    Jan 2004
    That's perfect! No need for a scope or anything, you should be able to do your project with that document alone as reference. Lucky guys!
    http://hallert.net/
  9. #29
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    niice find. now i gotta save up for a v1
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  10. #30
    Newbie btown's Avatar
    Mar 2004
    Irvine, CA
    wow that is awesome. now we can do everything we want with radar signal, lowering music vol, graphic radar display, custom warning sounds, customize with gps, someone just needs to write a program. unfortunately i only know visual basic, and i'm not sure how to listen for signal with it. plus i have the escort right now, but i'll buy the v1 if there's a program. actually i may just buy it anyway.
  1. Solution for your audio from "COMPUTER TO SPEAKERS"
    By emayers04 in forum General Hardware Discussion
    Last Post: 10-15-2004, 03:03 PM
  2. Help me pick a solution please
    By electron in forum Newbie
    Last Post: 09-14-2004, 01:02 PM
  3. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 11:29 AM
  4. Possible solution to the inverter dilemma...
    By gregulator in forum Power Supplies
    Last Post: 08-07-2001, 10:38 AM
