Well, I don't have a V1, but I think I know how we could make it work. You know how it uses regular modem wires to communicate between the remote display and the main unit? If we were to grab that info, then we could maybe get something working![]()
How many of you out there have a Valentine One? We need a serial port interface, and we need help! It would be great if FrodoPlayer would pause if a certain band of radar was at a >(some value) intensity. What do you guys think?
Compaq v6719 Athlon X2 tk-57
Xenarc 7" Dash Install, iGuidance w/ iGPS 500
HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
94.3% of all percentages are made up
I did some more searching...and finally found the thread that talks about this that I had read before...
Radar Detector
This product is very similar to what I want..http://www.jaricdesign.com/products.htm
It would be awesome if the Radar would only be reported if it was out of the norm for your longitude/latitude. The number of sources and strength of each radar signal could be monitored for every location you would ever drive.
See.... the V1 DOES use phone cables to communicate. Our job is to intercept them, reverse engeneer them, and make a parser for them.
i actually came across the same thing today. I have a V1 as well. I think it would be awesome if we could figure out what each of those wires from the telephone do. Then we could probably write up a program to retrieve long/lat when the intensity passes a certain threshold. This would also allow us to permanently install our detectors and use the computer as a remote display.
Exactly what I was thinking. Here's how to test: hook up the remote display cable to your modem and open up hyperterminal and watch the communication. The thing is, most people have EPIA boards, and those have only 1 PCI slot, which would have to be used for a modem.Originally Posted by Tred
Originally Posted by 0l33l
http://store.yahoo.com/pcsurplus/56kvsgsthexu.html
Yep. Now we have to see if Valentine 1 uses analog or digital signal. We want it to be digital, the same commands every time. We need to intercept and log the commands, and try to figure out what they mean. Then someone could write a program. I did make a callerid program using the modem, but I don't have a V1, and don't plan on getting one for a while.Originally Posted by egeekial
Don't invest any time trying to use a modem just because it uses a phone cable. Your best bet would be a parallel port interface.
Chrysler 300 - Fabricating
http://hallert.net/
Easier to test it with a modem.Originally Posted by Chairboy
