Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: grounding motherboard
  1. #11
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    so i should only ground one standoff?
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i've used motherboards without any grounding at all with no problems. Maybe try running without ground to see if everything goes good then ground it if you have a problem?
    肚子笑痛了
    S60 Install
  3. #13
    Grounding everything helps keep noise to a minimum which means a more reliable system.
  4. #14
    May 2003
    Miami, FL
    Quote Originally Posted by turbochris
    Tis true, but I have also heard of people on here grounding their motherboards and getting more problems.
    肚子笑痛了
    S60 Install
  5. #15
    Nov 2004
    Seal Beach, CA
    Stupid question, but since there is a Ground on the ATX power connector, wouldn't that "ground" the motherboard? Is it really necessary to run another ground? (And no, I know absolutely nothing about electronics or electricity)
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
  6. #16
    Newbie Slimline's Avatar
    Nov 2004
    Arrow
    ^^^^^ I'm thinking that too. When working on a standard PC case, all you have to do is touch a piece of bare, unpainted metal to ground yourself. If that's the case, then you're fine as long as you attach a ground wire from a piece of the metal on the PSU to the chassis of the car. That makes sense to me. Ask an engineer, if you know any
  7. #17
    Nov 2004
    Minneapolis
    then again, they put grounds there for a reason. i once had crazy electrical problems in a car, figured out one of the many grounds was loose. just one.
  1. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
  2. Motherboard Vibrating, will it be damaged??
    By syclone477 in forum Newbie
    Last Post: 05-01-2004, 11:28 PM
  3. WT: Celeron Setup for Slot A motherboard
    By EBoundEE in forum Classified Archive
    Last Post: 04-28-2004, 03:06 PM
  4. Grounding concern (not normal grounding issue)
    By supralightning in forum Power Supplies
    Last Post: 03-22-2004, 12:02 AM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 07:56 PM
