Results 1 to 10 of 17
Thread: grounding motherboard
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    is it nessesary or will there be any issues if the motherboard screws are not in metal like a normal case? sound or other?
    i'm planning on building my own plexi case, cause i have some layin around, and it looks cool.
    Nov 2004
    Minneapolis
    nothin?
    Quote Originally Posted by fuctup
    There is actually no way of telling until you do it. Though even there are it is very easy to ground a mobo.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Several treads address grounding in detail including plexi cases.... do your reSEARCH.
    TruckinMP3
    Read the FAQ!
    Nov 2004
    Minneapolis
    i did search. motherboard grounding, motherboard ground, motherboard grounds, searching by title gets nothing, searching normally gets tons of posts about all different things.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Try these search terms:
    "motherboard AND ground AND plexi" gives a thread called "Plexiglass case fabrication".
    "motherboard AND ground AND wood" gives a thread called "wood".
    "mobo AND ground AND plexi" gives a thread called "Mobo: Ground on MDF/Plexiglass?".
    "mobo AND ground AND wood" gives a thread called "grounding".
    All these threads seem very relevant to grounding on non conductive cases, and I wasn't bombarded with "tons of posts about all different things". I don't know what you were doing wrong when you searched.
    Make use of the boolean operator "AND" when searching. It's a fairly standard thing on vbulletin.
    Nov 2004
    Minneapolis
    ya i found the plexi case fab one after posting, thanks
    ground everything. Your mobo, PSU, hard drives, optical drives, I make ground straps out of the shielding inside shielded cable, ground them all together and have one tie to the car body ground
    Nov 2004
    Minneapolis
    so whats the best way to ground the board? standoffs with a wire connecting them all ? what type/gauge of wire?
    Make sure the hole you pick for the standoff is tied to the ground on the power supply connector. Use some 16 ga wire, thicker is better.
  1. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
  2. Motherboard Vibrating, will it be damaged??
    By syclone477 in forum Newbie
    Last Post: 05-01-2004, 11:28 PM
  3. WT: Celeron Setup for Slot A motherboard
    By EBoundEE in forum Classified Archive
    Last Post: 04-28-2004, 03:06 PM
  4. Grounding concern (not normal grounding issue)
    By supralightning in forum Power Supplies
    Last Post: 03-22-2004, 12:02 AM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 07:56 PM
