Results 1 to 9 of 9
Thread: Car Relay ?
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Car Relay ?
    Need Help
    I need to find out what the size of the standard 30 amp relay this one with 5 pin (30,85,87a,86,87)
    How long and with there pin is and the position of the pin
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    New York
    not the smallest part in the world.
    would estimate about 1" x 1" 1" or so, plus some slack for the wies comming out on the bottom side.
    Just measured one. It is 1.5" from the top of the relay to the end of the pin. That is not including the little wing (see pic) that some of them have so that you can screw it up against something.
    edit: the one i measured is a bosch 12V 30A sn:0332209150
    May 2004
    Denmark
    But but I need to know the deminsion of the pin an the position so hold to it on a PCB
    Ditail at 4u2n.dk
    Here
    Maybe better if you just buy one and mark off your board. Sounds like you are in the middle of a project so you will have to buy one anyhow.
    Aug 2004
    Quote Originally Posted by 4u2n
    You wouldn't want to solder the relay directly to your pcb. You need a socket.
    00 Galant
    armadaE500 P3-660 320M 20G, lilliput, audigy2NX, slim/slotLoad dvd/cdrw, cardReader
    sony rm-x2s, bu303, xmDirect
    xpPro sp2, frodoPlayer 1.09, iGuidance 2.0, custom voiceRecognition
    custom shutdownController
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    an'if you wire the car's relay socket to a connector for your board/project, won't have to buy one.
    •Micke
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Google for TYCO VCF4-1000 or NTER95-160. That is a PCB adapter for the above relay.
    Attach is the component file in Express PCB I make for the above adapter download it and remove the .txt ext (its ext is .p)and put it in PCBComponents_Custom folder of your ExpressPCB installation dir.
    Attached Files Attached Files
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2004
    Denmark
    Quote Originally Posted by justICE
    yes i have now buy to today, and you are right i'am in the middle of the project.
    Quote Originally Posted by djScript
    In a way i will solder the relay directly to my PCB, you see it when i'm finish with it..
    Quote Originally Posted by grepzen
    No socket, I will make shomthing my self.. wait and see..
    Quote Originally Posted by MatrixPC
    Big thanks for you help, easy to the size on paper..
    Ditail at 4u2n.dk
    Here
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  3. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
  4. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
  5. god damn university car regulations
    By MikeHunt79 in forum Off Topic
    Last Post: 09-27-2001, 12:02 PM
