Electrical Insulation
Hi all,
What is a good substance to use as a permanent electrical insulator. I need to insulate the positive/negative power lines from the PC power supply to my LCD panel where they go into the little stripbaord circuit I have built (which includes the two brightness contrast pots) and connectors to pins 1/2/3/15/16 of the LCD.
I was thinking of using Araldite (for those in the US who may not have this, this is a resin/hardener combo that dries very hard).
Does anyone else have a view on this ?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
