:( So frustrated with my WRX car computer!
I just bought a Lilput in dash touch screen for my WRX from digitalww with the intent for mounting it above my c134 travla case. I sawed off the end of the c134 so it would fit depth wise. The face plate is a bit too wide for the front bezel which I was going to get creative on. However, the front plate for the Lilput is significantly wider than the front bezel. Probably by a half inch or so. I suppose my question is where can I find if at all a bezel for my car that might have wider openings? or if you are familier with the WRX do you have any suggestions? I'd rather not hack up the bezel as the lilput is so big any adjustment I would make would probably look pretty heanous. I would mount just the screen down there as I have seen people do but I have no experience with bondo or any other type of fabbing. Maybe someone knows a way to do that easily? I can get some pictures up if someone would like to see. Thanks in advance for the help.
