Results 1 to 10 of 18
Thread: Moving Xbox DVD drive
    Nov 2004
    I need to move my DVD drive out of my Xbox to put it in the dash, while keeping the rest of the Xbox out of the way. The major concern that I have is the ribbon cable. How can I extend the length of the dvd from the mother board of the box? Any help/ suggestions would be greatly appreciated.
    Also, does it matter the order of which the drives are connected? Currently it is Mother board, dvd, hard drive, so can it be changed to MB, HD, DVD?
    Thanks guys in advance
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    I thought an XBox uses a standard 40-pin IDE ribbon connector? The power plug is different though - it still uses 12volt but the connector is different.
    There was another post on this board saying an IDE cable can only be extended 36 inches. So I think you would be screwed if you were extending it further than that.
    Search the forums on xbox-scene.org(.com?) and see what others have done. Good luck.
    -HD
    Newbie fearthepenguin's Avatar
    Mar 2004
    It can be relocated, but remember the max length that an IDE cable is supposed to be is 18 inches. Much over that and you could start running into trouble. I did see one guy make like an 8 foot IDE cable, I believe on this site way back when it first was getting on its feet, but Im not sure how that ended up working out.
    Jason
    It gimme the jibblies
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    good lord 8 foot IDE cable..hahhah
    throw a moon
    heuvos vin chevos
    Mar 2004
    Yeah, If I remember right, it was in a station wagon and he had a picture of himself and a buddy holding this monster cable.
    Jason
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    yeah, he used cat 5 for the extention right?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Jun 2004
    Houston/Georgetown TX
    top answer the question:
    no it doesnt matter which order the drives are in on the ide cable as they are set up master and slave.
    but as for moving it, not only do you have to move the ide cable but there is another cable that connects to the dvd drive that has power, eject and some other stuff on it, that is another 10 wires (they are yellow). but if your going to move the whole thing you should look into swapping in a better dvd drive for more compatibility (http://www.xbox-scene.com/articles/samsung-616t.php)
    that should answer enough questions for now, it seems to be a daunting task
    Carputer Progress:
    [!!'-------] 25%
    have to fabricate screen mount
    have to start over, lilliput died, 1st laptop broke, have to sell the 2nd one. damn
    Jun 2004
    you can make ide calbe much longer if you use 80 pin insted of the older 40 if you serch on here u will find this has been diskused there are many people with 15 ft ide
    Variable Bitrate egeekial's Avatar
    May 2004
    Why would you make a 15ft IDE cable? I don't understand....
    Just get the USB adapter. It may cost more, but it's so much easier!
    Aug 2004
    Not much hope for a usb dvdrom on an xbox I'd think. People make these calbes because they do not want to deal with the issues of usb, or don't have usb, or don't want to waste cycles on it.
  1. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 01:16 AM
  2. WTB: Laptop DVD drive or IDE adaptor
    By Fosgate in forum Classified Archive
    Last Post: 10-24-2004, 02:32 AM
  3. DVD DRIVE Adaptor
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 03:15 PM
  4. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
  5. Installing DVD drive in car
    By marley in forum General Hardware Discussion
    Last Post: 07-13-2002, 07:57 PM
