Results 1 to 5 of 5
Thread: another inverter problem
    Nov 1999
    state college, PA, USA
    Post another inverter problem
    I was trying to put my inverter inside my car. so i used some power wires and I attached one end to the battery. the problem is connecting it to the inverter. First I connected the positive and when I try to connect the negative, sparks start flying everywhere! am i doing something wrong???
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Wink
    You may be connecting it backwards, or the sparks may just be caused by the surge as the inverter comes on.
    Either way, are you qualified to do this sort of work?
    Nov 1999
    Post
    hellz no, I'm as dumb as they come when it comes to electircal things. hehe
    I might fry my car soon... but I'm having fun! I really doubt that i'm connecting it backwards but let me try again......
    Dec 1999
    Buena Park, CA
    Post
    Disconnect the ground wire from your battery. (Please oh please) use wire that is at least as thick as the wire coming out of the inverter. Run the positive line, putting a fuse within 18" of the battery. If the inverter is inside the car, find a good ground point (I like to use the seat mounting bolt, or the seatbelt mounting bolt). When the inverter is completely connected, reconnect the negative cable to the battery.
    KG6OQD
    www.americansandassociation.org
    Jan 2000
    Smile
    What AVGeek said is good, but one thing should be mentioned. Using the seat belt bolt is generally a bad idea. While it is true that it is a good ground, it is unsafe to use it as such. Those bolts have very specific torque specifications. Most of the time, torqueing the bolt to that spec is enough to crush your ground wire. Therefore, if your wire is not crushed (thereby ruining your ground) your bolt may be too loose and may back off while driving. This would obviously be very bad in a collision. There are many screws and bolts in a car, so it is easy to find something more suitable.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
