Results 1 to 2 of 2
Thread: Check out this MiniPC
    Sep 2001
    Post Check out this MiniPC
    Found this while surfing, might be of interest, it's tiny, fast, even takes DC in at 18V -
    http://www.tigerdirect.com/applicati...?sku=A259-1000
    Specifications:
    Processor:
    Intel Celeron 1GHz processor (FCPGA)
    370-Pin processor socket
    System bus frequency at 66MHz
    Memory:
    128MB SDRAM; Upgradable to 256MB
    One 144pin DIMM slot for PC100/PC133 SDRAM
    Storage:
    10GB UDMA hard drive
    24X Max. CD-ROM drive
    Video:
    Intel 82810E built-in full motion video accelerator
    H/W motion compensation for S/W MPEG2 at 30fps
    4MB of video memory (shared)
    Supports 1280 x 1024 pixels resolution at 24bit color
    One S-Video Out port
    One AV Video Out port
    Speakers and Audio:
    Built-in 16-bit stereo (Sound Blaster / Adlib compatible)
    Full duplex 3D stereo sound
    Built-in speaker
    One 3.5mm microphone in port
    One 3.5mm line out port (using active speakers)
    Communications:
    Built-in 10/100Base-T Ethernet (RJ45)
    Built-in 56K V.90 modem (53K max. per FCC regulations)
    IrDA
    Peripheral Connections:
    Two USB ports
    One 9-pin serial port
    One 25 pin parallel port (EPP / ECP)
    Keyboard and Mouse:
    One 6 pin PS/2 mouse port
    One 6 pin PS/2 keyboard port
    Electrical Requirements:
    Line voltage 100V AC (100V to 130V AC) or 230V AC (180V to 260V AC)
    Frequency: 47 to 63 Hz, single phase
    Power in: DC 18V / 3A
    Maximum power 64 Watt
    Weight and Size:
    System approximately 950g (2 lbs)
    System Dimensions: 157mm x 146mm x 45mm (6.18" x 5.75" x 1.77")
    Variable Bitrate dbinnc's Avatar
    Sep 2001
    Greensboro, NC
    Post
    ya, I posted it b4, but not from tiger. there is another level up that has firewire and i think dvd. pretty sweet tho.
