Results 1 to 3 of 3
Thread: Question on Pioneer Unit with RGB
    May 2003
    Hi, this is kinda hardware/video, so I stuck it here.
    I FINALLY have the option of trading in a broken screen/head unit at bestbuy, and want a little info on the rgb specs. I searched and couldnt find anything on the particular unit, which is found here.
    Head Unit
    Now I read you can convert rgb to vga with adapters from ati, ect. Thing is I think this product says rgb, but has a weird connection that only the pioneer dvd add on will work with. Can someone clarify this please, I would love to grab this and use it with vga, instead of composite. Thanks
    I also have the install manuals and user manuals for both units if that helps, just doesnt seem like I can upload to a server from work
    Thanks guys
    [------X---] 70% done, though that number goes up and down all the time
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Seriously, maybe you should . Give it a try! Everyone's doing it! Hell all you would have to do is type in RGB or A/V in the search field. If you did, you would find out that the resolution would be utter ****. That is all.
    Quick! To the Popemobile!
    May 2003
    Quote Originally Posted by BiohazrD
    Thanks, I never thought to search, what would I do without you? I did search, and I also provided a link to the product, and said I had the install manuals available...which would mean I DID research since I dont own the product yet. I dont see how rgb to vga could be worse than just composite, and since I dont have much choice in what I can get with my exchange plan, I wanted to know if this works! Jesus, get off your hi-horse already. The question wasnt on Resolution, it was on the connection..and since I hav not dealt with rgb much, thats what I needed!
  1. Fold out indash LCD/DVD RGB question
    By miztahsparklez in forum LCD/Display
    Last Post: 08-12-2004, 07:17 PM
  2. Replies: 3
    Last Post: 06-05-2004, 12:23 AM
  3. Hacking OEM head unit question, PINOUT provided
    By el bob in forum General Hardware Discussion
    Last Post: 02-18-2004, 09:04 AM
  4. pioneer avx 7300 without master unit
    By SC_Highlander in forum LCD/Display
    Last Post: 04-14-2002, 07:53 PM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 03:57 PM
