Results 1 to 4 of 4
Thread: Opus to power monitor???
    Oct 2004
    I have the opus 150 and I want to try to power my touch screen with it. The touch screen I have is a 3m brand and I have no specs on it (10.4in, 12volt input). I dont want to just wire the screen into my truck because voltage fluctuates in a vehicle and I dont want to chance the screen not being able to take voltage spikes. I was thinking that since the opus is regulated it would be the best route, but I dont know if the opus could handle it....
    Thanks for the help
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    You could, but I wouldn't recommend it. Just get a 12v regulated car dc-dc supply from radio shack & use that...making sure its rated high enough to power the screen.
    Low Bitrate phord's Avatar
    May 2004
    That's what I did. And lots of other people have done it, too. Works great!
    Sucks that you had to start a new thread over it, though.
    Best way to power the liliput touchscreen?
    Carputer-II: Infiniti Q45
    Simple setup, NAV-only
    Tablet PC :: FP :: iGuidance
    Status: Ghetto, baby!
    Carputer-I: '99 Honda Odyssey
    Dual monitor, separate outputs: Finished
    FP :: iGuidance :: WinDVD :: EPIA M-10000 :: Opus 150w :: In-dash/On-dash
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by futuresweets10
    Thanks for the help
    I use the 12 volt from a DC to DC PS. Make sure you connect it correctly and do it.
    TruckinMP3
    Read the FAQ!
  1. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-16-2004, 11:38 PM
  2. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 07:14 PM
  4. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 02:17 PM
  5. OPUS power supply
    By xenonflx in forum Newbie
    Last Post: 11-30-2003, 05:06 PM
