Results 1 to 4 of 4
Thread: Windows freezing
    Jun 2004
    Windows freezing
    Okay would really appreciate any ideas or help any one can give me. My problem is that I have a 15 ft ide cable (I donít need to be told that this wont work) and it workes with a full-sized cd/dvd but when I try and use it with my slim slot load drive windows freezes on startup. If I boot to safe mode everything works even the slot load drive just cant figure out any way to get it to get past the normal startup unless i plug the slim drive in with just a normal calbe then it works.
    Thanks for any ideas any one can come up with I just cant figure out y it would work with my full-sized drive and not with the other and y the slim one works in safe mode.
    Jun 2004
    Any one have any ideas anything I can try I am just getting really frustrated
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Your cables are too long (i can tell you don't need to be told this won't work) different units will place different demands on various signals traveling those 15feet. (and they'll do so at different times).
    One thing you could try is placing a filter (ring magnent) around the cables to see if that reducees noise that may be causing the heartaches.
    & even if you do get 15' IDE cables to work temporarily.. you'll be a freak of nature.. -- they exist sure enough.. but they're not easily replicated.
    Jun 2004
    The North, Manchester
    and this wont work
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Replies: 11
    Last Post: 10-08-2004, 08:59 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  4. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
