Results 1 to 9 of 9
Thread: Quick question about CPU Fan voltage..
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I want to add some cooling to my carputer and I had some case fans laying around.. They are all 12V but I just measured the output on the wire coming from my EPIA M10000 and it's 5V. Are there any 5V fans out there? I couldn't find any at svc.com.
    If I use a 12V fan will it be OK? I know it will spin slower but will it damage anything?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    Five volts may not reliably start the fan, but other than that, it won't damage anything.
    Oct 2003
    Poland, OH
    Are there fans that move some good air that run off 5V?
    Nov 2004
    just get the 12v from the hd cable. if the mb needs a fan connected to run, take the yellow wire from the fan, and connect it to the mb header w. another fan connector.
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Quote Originally Posted by tbird2340
    You can take a 12V fan and take the power from the disk connector
    If you think it run to fast you can move the ground from the fan to 5v then the fan only get 7v, must of 12v fan can run at 7v and do not make as much noise.
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    I think the fan will draw more current at 5v than at 12v. Is this true? I think it is...
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Just hook up that 12V fan to the car power. I don't think you are going to burn the fan. It just spin faster and more noise. All my cooling fans are hooking up directly to the car ACC wires.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2003
    Poland, OH
    What do you have the ground wires hooked up to?
    Sep 2003
    Beach City, Socal
    Ground can be connect to the ground wire that going to your PSU/mobo or any ground point on your car.
  1. Quick grounding question
    By GingerPrince in forum Power Supplies
    Last Post: 11-06-2004, 09:28 PM
  2. DIN Case Question and CPU ?
    By inothome in forum Newbie
    Last Post: 10-26-2004, 04:08 PM
  3. quick question re: laptop power
    By mkerr in forum Power Supplies
    Last Post: 10-22-2004, 12:37 AM
  4. Quick question about multi-channel amps
    By imprezive one in forum Car Audio
    Last Post: 08-06-2004, 02:23 AM
  5. CPU Swap question
    By Mitokondria in forum General MP3Car Discussion
    Last Post: 07-25-2004, 04:31 AM
