Results 1 to 9 of 9
Thread: Pictures of XM Direct box
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    I was wondering if someone can post some pictures of the connectors on their XM Direct box or if you know if the XM commander box will with with the home brew cables on here to connect to a pc. I am asking because I have a commander unit currently and would prefer just to use that box rather than throw another $50 at the setup. One of the differences it seems is the power source. My commander unit has its own power supply that runs to acc etc. so I am wondering if I can just ignore that part of the cable or if the direct box has that power connecter as well. Any help anyone can provide would be appreciated.
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    Post some pics of YOUR connectors, and we might be able to help!
    www.i-hacked.com Hardware hacking articles
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    My unit is burried under my dash and is a good hour or more to get to so I did a google search and came across this:
    Starting at the bottom going up there is the XM Serial connector, line out for fm modulator, rca line out, and power
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Commander should work, look here: http://www.mp3car.com/vbulletin/show...der#post284629
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    So do I just omit the power wires from the cable and I'm set? or do I still need to connect them? I would imagine no since it has an external power source but just want to double check.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    You have to use the power connectors. As far as I know The XM commander is the XMDirect with a control unit. So just disconnect the control unit and use the homebuilt cable in it's place.
    肚子笑痛了
    S60 Install
    Jun 2004
    South-Central PA
    I would think you don't need to use it. He said the commander is already powered.
    The cable comes with a power cord and cig.plug on the end, it plugs into the 9 pin serial connector. You just don't need to use it. You won't need to cut or modify anything.
    Ask HybridMike to be sure.
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    correct, the commander has its own power plug, finally found some xm direct pictures on xm411.com and that doesn't have a power plug so I think its safe to assume that my external power adaptor will do the job and I dont need to use the one built into the cable.
    Jun 2004
    South-Central PA
    Let us know will ya'? (When u get it setup)
  1. Xm Direct Cable Ready For Shipping!!!
    By HybridMike in forum General Hardware Discussion
    Last Post: 07-06-2005, 10:58 AM
  2. Finally, got the XM Direct working as PCR
    By kingtut in forum General Hardware Discussion
    Last Post: 11-16-2004, 09:20 AM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  4. XM Direct / PCR / TimeTrax - The saga continues.....
    Last Post: 10-15-2004, 04:40 PM
  5. Direct Xm working as a XMPCR!!
    By KMorphosis in forum General Hardware Discussion
    Last Post: 10-07-2004, 11:37 PM
