Results 1 to 10 of 12
Thread: NTFS or FAT
    Oct 2004
    NTFS or FAT
    I am useing a laptop hard drive (brand new) in my mobile PC. I tried installing windows on it and when set up formatted the disk it said that the hard drive couldnt be formatted, and possibly could be bad. A friend suggested that maybe a lap top HD couldnt support NTFS (which is what I was trying to use) and that maybe I should do FAT. What do you guys think??
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    NTFS. More secure. A file using FAT will take up more space than NTFS because of the way it is built.
    FLAC alti's Avatar
    NY
    What OS?? XP?
    I cant think of a reason a laptop drive would not support NTFS what is the age of the laptop/drive?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Constant Bitrate blackpacu's Avatar
    Jul 2004
    Setauket
    Its possible that the HD is bad, Can you detect it correctly in the bios? Did you oriente your cables and converter properly?
    Id check those first.
    amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
    now to put it all together
    Oct 2004
    I know the converter is set up correct unless the converter is labled wrong. When the computer boots up it does find the hard drive, so I know its seeing it. the hard drive is brand new (I had to take out out of the factory static wrap)
    FLAC alti's Avatar
    NY
    can you format it in fat ??? or not at all??
    if you can format in fat then you can always convert to ntfs
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Oct 2004
    Quote Originally Posted by alti
    I havent tried FAT, but if I can do FAT but not NTFS the HD is still broken and I still dont want to use it.
    Banned eatyummypuppies's Avatar
    Feb 2004
    li, ny
    Either the drive is bad or you have it installed incorrectly.
    Always go with NTFS over FAT16/FAT32. It's a journalling filesystem. Meaning, it's able to better handle improper shutdown/power failure without corrupting the entire allocation table.
    FLAC alti's Avatar
    NY
    Quote Originally Posted by futuresweets10
    If the HD is broken it will not format at all in Fat or NTFS, FAT and NTFS are just file systems and are tables that reference how data is stored on the disk NTFS is more efficent becuase is stores data in smaller peices so there is less wasted space
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
  2. Windows XP - NTFS Support?
    By millec in forum ME Archive
    Last Post: 03-03-2003, 03:23 PM
  3. The Fat and The Furious
    By MikeHunt79 in forum Off Topic
    Last Post: 08-14-2002, 09:54 AM
  4. Turning scandisk off in WinXP on bad shutdown
    By Defiler in forum Software & Software Development
    Last Post: 03-07-2002, 03:37 AM
  5. What did Fat man bring you?
    By lstrunk in forum Off Topic
    Last Post: 12-28-2001, 06:17 PM
