Results 1 to 10 of 18
Thread: First draft design of my carputer *pics*
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    This took me all day, but I am not a self proclaimed novice in MS Visio 2003 Please tell me your comments, criticisms.
    • I didn't draw the antenna for the 802.11G yet. I'm also not sure if I will install it on the Cardbus or PCI slots. Both are free for now. I have heard better things about the cardbus flavor, I just need to find one with an external antenna plug so I could hook up the 6" mag antenna.
    • The AM/FM will be a radioSHARK. TV will be settled at a later time, its not a priority. I'll probably wait until that dude finishes the TV/AM/FM project.
    • I also didn't draw the VGA cable for the Lilliput, because I'm still not sure how the Lilliput is connected. Is it as simple as running the VGA extension and USB extension from the rear of the car up to the screen?
    • I listed the DC-DC power supply as an Opus 150W, but I may downgrade to a 90w if I feel its not necessary to power all of those components. I'm mostly worried about the Lilliput, since I'm not clear as to whether I have to have it connected to a molex yet.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Quote Originally Posted by Bailey
    Yup! Thats it. Some people have extended the mini din connector, but the way you describe will be great as well. Just different ways of doing the same thing.
    2005 Ford Focus ST
    Constant Bitrate Rith's Avatar
    May 2004
    P'cola, FLA
    wow i like it. Good luck with it, make sure you keep us up to date with your progress reports
    CarPC Status:
    [||..........] 12%: Planning
    Have:
    • IRman • PS2 Remote • USB 2.0 Powered Hub • Backup HD
    Coming Soon:
    • Aopen Pandora • Celeron M 1.4 CPU • 256/512 DDR2 So-DIMM RAM • Lilliput 7" Touchscreen VGA • Car Power Supply (M/Opus)
    Nov 2004
    NYC
    Quote Originally Posted by gospeed.racer
    Ohh I get it. If I extend the mini din connector, I may have trouble upgrading in the future. Its better to just run the two cables. I wouldn't be much harder anyway.
    Oct 2003
    My suggestion to you - run the 12v+ and amp turn on on one side of the car, and the rest on the other. You will thank me.
    Dan
    Nov 2004
    NYC
    Quote Originally Posted by dmurray14
    Dan
    Funny you mentioned it, it turns out it will be easier to run the 12V up along my radiator and upside the passenger side. There is a grommet there that will be easy to punch a hole in. Why did you mention it though?
    Dec 2003
    Portland, OR
    ...you want to keep the "sound" wires separate from the "voltage" wires, you get less interference that way.
    2005 Ford Focus ST
    Nov 2004
    NYC
    But... cars have speakers on both sides. So running the power near one of them is sort of inevitable.
    Dec 2003
    Portland, OR
    yes, but not *directly* beside them. Just keep them seperated, they dont have to be on opposite sides of the car.
    2005 Ford Focus ST
    Nov 2004
    NYC
    Here is the second draft. Not enough changes for a new thread. I drew the VGA, moved the 12V source, and put power from the opus to the Lilliput. I think thats it.
    When I do the actual install I'll make sure not to tie the speaker and power wires together or anything, thanks for the tip.
  1. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  2. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  3. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  4. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
