Results 1 to 6 of 6
Thread: Any companies out there make custom pc cases to your spec?
    Newbie thejames's Avatar
    Nov 2004
    [Also posted on digital-car]
    Hi all,
    Been researching how to go about installing a carputer into my e36 coupe. Ive got a "vision" and was wondering if there are any companies out there that would make me a custon mini-itx case to my specification. It'll be a weird kinda L-shaped type thing to fit perfectly in the glovebox. And, id like it made out of perspex. Thing is, i need info ideally on companies based in the UK.
    I can get a custom box made up by a company i know of but they do not have any kind of expertise on the computer side. Ie. They wont be able to provide the correct mountings or advise me on how the components should be fitted or ventilated etc.
    I know people undertake these DIY projects all the time and although i have a basic knowledge of computing, actually fabricating a suitable housing is beyond me. If i select and buy all the components, is there a company out there that can make it up for me? I already have a rough idea what switches/inputs/outputs id like front and rear of the case.
    Cheers guys(and lasses),
    Jim.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    do the drawings, or make a mock up out of cardboard and take it to your local plastics shop
    should do the trick, otherwise send the above to me and for a small, phenomenal fee I can do it for you
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Nov 2004
    Cheers matey. Im sure theres a company near me that wouldnt have any trouble knocking the box up for me but they wouldnt be able to put the components in for me and therefore couldnt make the appropriate holes for inputs/outputs and switches. Also, as i said, ive built a pc before but wouldnt know how to install the components correctly in a custom box with no mounts.
    Quote Originally Posted by thejames
    Go to a local PC shop (not PC world), talk some geek into doing it for you
    Sep 2003
    Northeast Ohio
    If you are able to provide the dimensions for your case that will fit your parts to a company that can make up a box for you it seems to me that they could also fit your parts in it as well. Once the box is made then place the parts in and carefully mark/layout/measure the mounting holes and drill some holes in it. Same goes for the port layout as well. You just need to work with them. It will probably take several visits.
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
    Nov 2004
    Cheers Unc, in case i do go about installing the parts myself can someone please list me a bunch of pointers that i should watch for. Perhaps certain orientation of certain parts? What things must have ventilation (although as i understand it the lower voltages of certain mobos dont even require a fan??)? What things must be insulated etc etc etc.....
    Cheers
  1. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  2. How do I make my PC boot faster?
    By dudah85 in forum Software & Software Development
    Last Post: 08-06-2002, 02:32 AM
  3. Would this motherboard make a good Car PC?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 06:33 PM
  4. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
  5. spray painting pc cases
    By asteroid in forum General Hardware Discussion
    Last Post: 09-24-2001, 07:24 PM
