Results 1 to 7 of 7
Thread: A good Aux-In Challenge
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Post A good Aux-In Challenge
    Well, i am trying to modify my AIWA-CDC-X517M to have rear Aux-IN. However, i cant seem to figure out where to solder in the connectors on the circuit board. Anyone feel like looking at it?
    http://www.tjhsst.edu/~dbagley/cdc-x507m-board.jpg
    http://www.tjhsst.edu/~dbagley/cdc-x507m-board-big.jpg
    Thanks so much!
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Post
    That's the wrong side of the board to be useful, there aren't many ic part numbers visible. I'd start at IC501 on the left. Get the part number and see if you can find a data sheet on the web. It looks like an audio amp ic from the pin layout (although it might be a switching regulator ic). If an audio amp, I would trace the inputs back, and go from there. That's what I did with mine. Pictures and schematics of my HU mod on my site.
    Also, there are aux-l and aux-r marked on the board, that would be a bit of a clue too.
    Hang on a minute, just looked at some specs and this unit has a front panel aux in already. This is an absolute doddle to mod, you don't even have to add an aux-in like I did, you just move it.
    Rob
    Jun 2000
    Virginia
    Post
    right, it does have front aux in, but it is on a removable face plate, so i dont know where to solder it onto the board.
    Apr 2000
    Bedfordshire, UK
    Post
    Trace the lines back to the main board.
    Rob
    Feb 2001
    louisville,ky,usa
    Post
    If I was going to factor a guess.. it looks like the AUX-IN is.. Top Right Hand Corner, 5W761 on that board..
    That should be visually apparent to you though...
    I cheat, I own an empeg.
    Meskimen's Law: There's never time to do it right, but there's always time to do it over.
    http://civic.mp3car.com
    Apr 2000
    Bedfordshire, UK
    Post
    sw761 is probably a switch by it's denotation.
    Connectors are usually denoted by a J and the a number.
    And since the aux in is on a separate removal panel, the connector for it wouldn't be in the main unit.
    Rob
    May 2001
    Thessaloniki, Greece
    Post
    It makes sense... those solder padS are on the edge of the board, next to the face plate. The only thing smashr2k has to do is to check continuity with a multimeter between them (pads) and the front panel's aux in jack (with the face plate on the headunit of course).
