Results 1 to 6 of 6
Thread: temp battery power to the lighter plug?
    May 2004
    is it possible that to power the cigarette lighter plug while the engline is cranking?
    right now when I crank my car, it automatically shut off the power to the cigarette lighter.
    thanks
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Sure, My suburban has the cig lighter powered all the time on, off or crank.
    TruckinMP3
    Read the FAQ!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    yup. Wire it straight to the battery. It's probably wired to your ACC, which is off when the car is cranking.
    Tidder
    Try RevFE
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    It's also possible that the lighter is always powered, even during crank, but while cranking the voltage drops low enough to make whatever you're trying to run cut out.
    May 2004
    my inverter survives in cranking if it's wired directly to the battery, but not when I wired it to the lighter plug. so i think the lighter is not powered while cranking.
    I want the cigarette off when the engine is off so I don't want to wired it diectly to the battery.
    any more suggestions? what about using a timing circuit that temporary draw power from the battery for 5 sec while cranking?
    Aug 2004
    Brookville, IN
    It's quite possible that your cigarette lighter is powered during crank. The loss in power is probably due to the tiny wires that are used to wire your cigarette lighter. They don't really supply enough power for a large inverter, and the voltage drop during cranking probably just pushed you over the edge.
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. S1 Standby Power Consumption Drain Battery?
    By Grayscale in forum General Hardware Discussion
    Last Post: 06-16-2004, 03:30 PM
  3. power carputer from the battery?? HELP?
    By fondoo in forum Power Supplies
    Last Post: 05-20-2004, 11:16 PM
  4. Cig lighter adapter to power PC?
    By Alphared in forum General Hardware Discussion
    Last Post: 08-03-2003, 10:14 AM
  5. Here's an alternative power source....
    By A Boy and his Miata in forum General Hardware Discussion
    Last Post: 11-21-2000, 12:44 PM
