If it is booting is safe mode it is proabably a driver or software issue (more likely driver). Just to make sure its not the power supply I would take it inside, plug it into a regular ATX psu and power it up just to test it. If it is drivers then I would start by searching the net for each device you have installed to see if anyone else has had the same issues. What are your system specs?
LinkBack URL
About LinkBacks
