Results 1 to 9 of 9
Thread: XM Trouble
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    XM Trouble
    Ok, I give up. I have to ask a question. I have been messing with this all night. I made my cable tonight, checked it like 50 times, have taken it all apart, resoldered, checked another 50 times, and nothing works. How do I know what port this thing is on? Should I see it in device manager? Frodoplayer take3 does nothing. I uninstalled, removed the directory, restarted, reinstalled. nothing. I have been searching the board, nothing that helps. Removed and reinstalled my com ports, nothing. Please help as I am getting very frustrated. Thanks.
    ATVMS.com
    Feb 2004
    Omaha, NE
    Nobody?
    ATVMS.com
    Jan 2003
    Ruston, LA
    Did you set the port for it in frodoplayer ?
    Did you make sure the cam trigger or lockout was not set to the
    same port and enabled ?
    You're not going to see anything in device manager, it's a
    serial device. Are you sure your serial ports are enabled ?
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Omaha, NE
    Serial ports are enabled, cam trigger and lockout are not set.
    ATVMS.com
    Jan 2003
    Ruston, LA
    What about setting the proper port for the XM ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Omaha, NE
    How do I know the proper port?
    ATVMS.com
    Jan 2003
    Ruston, LA
    Quote Originally Posted by sfay93
    What do you mean ?!
    Set it to the port it's plugged into or whatever the usb adapter is set to.
    Anyway, try this app:
    (set your port in comport.txt)
    Frodo
    Attached Files Attached Files
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Omaha, NE
    Thanks for your help. Trying something else helped alot. It gave me time to cool off and rethink what was going on. I checked my cable yet again and found that there was ground showing on pin 5 of the 8 pin din. I could not wire it so that that wasn't there so I ended up pulling the pin. The cable was for my ATI All in Wonder so I am sure they had something wierd going on there. Anyway, it works now! Just wanted to say thanks.
    ATVMS.com
    Jan 2003
    Ruston, LA
    Glad you got it working.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
  2. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  3. XM PCR External App
    By dug1967 in forum MediaCar
    Last Post: 08-04-2004, 11:35 AM
  4. Trouble Launching XM??
    By MikeH in forum FrodoPlayer
    Last Post: 07-19-2004, 10:49 AM
  5. homebuilt XM receiver
    By stevewm in forum General Hardware Discussion
    Last Post: 07-14-2004, 02:00 PM
