It's gotta be a fuse,
go check all the fuses again,
i did the same thing and some fuse like internalclock(or something) had blown.
If it's not a fuse,
its something bad, and beyond me...
I just got done installing an amp. I was about to go ride around to see how it sounded and when I started my truck I noticed I had NO interior lighting (dash / HVAC / cruise pods / etc). When I put on my parking lights I get nuttin inside OR outsie but when I put on my headlights JUST my headlights come on. Nothing else. No parking lights or anything.
I checked fuses and they look good.
What the heck could I of done!?!?
PS: I posted in general instead of audio so more people hopefully see it!
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
If it's not a fuse,
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
How did you hook the amp up? If you ran a wire form your battery (you should have) make sure you hooked up all the wires to the battery. Also check you should also have more fuses in the engine compartment.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Ahh yes.. I forgot about the fuses under the hood. I found a blown 15AMP. Replaced it with another 15AMP and turned my parking lights on and it blew instantly.Originally Posted by Naamanf
I had no problems with the amp and I thought everything went fairly smooth.
I ran a wire from my car battery's POS terminal to the amp. All that's on the battery are the two terminal cables..
What the heck??
This is teh suk!
Do you have a fuse on the positive wire coming from the battery to the AMP? You need a fuse inline on the positive wire within 18 inches of the battery.
-HD
Yes, I have a 50 AMP fuse about 6" from the battery inline with the power wire to the amp.
Maybe there is a shorted wire somewhere in your setup - maybe the positive and negative are switched or touching each other on your amp?
Also, where are the screen shots of your camera in action??
50 is a bit large to be usefull. My headlights are on a 25 or 30 I think.
TruckinMP3
Read the FAQ!
I see nothing that can be shorting it..
Screen shots are waiting for my Xenarc to arrive. I've been w/out a carputer since Monday!!!
did you try disconnecting the amp to see if it still blows?
肚子笑痛了
S60 Install
