Geniuses Needed - Mouse Won't Work
Well, I fried my motherboard last week and had to find another one. Put it in and everything works great, except I can't get my serial mouse to work. I need the serial mouse to work so I can use MouseRemote.
Configuration is:
Win 98
P/S 2 mouse connection on board
2 serial ports
On Board Sound - Disabled
Soundblaster sound card
Helpful Info.:
Windows device manager does not show the mouse.
The PS/2 mouse works fine.
When I disconnect both the serial and PS/2 mice, I do not get the windows "No mouse found" message during boot. Every other computer running windows has given me that message if no mouse is connected.
Does not work even if I try to manually install a mouse through control panel. The standard serial mouse will then be shown in device manager, but the mouse won't work.
Windows PnP does not find the mouse.
I have tried using different ribbon cables for the serial connection to make sure the problem wasn't cabling, but that doesn't help.
I have tried a different mouse to make sure there wasn't a problem with the mouse.
Device manager shows all com ports working properly without conflicts.
I have tried it with everything but the mouse unhooked/unplugged and still no change.
Any ideas?
Thanks in advance.
Kevin
See if it is the serial port itself that is dysfunctional. Plug something else into it. If it still doesnt work then i'd grab another mobo. If youre just using remotemouse for controlling winamp through a plugin and not to actually act as a mouse you don't need a mouse attached. The receiver can work by itself. Anywho, I know I didn't help much but maybe you got something out of this. I think I'm having the same problem with a 166 I have. Thank god I have a 90 that does the trick.
- JustAGuy
Retired Admin
Does device manager show your serial ports?
Have you tried running the 'Add New Hardware' wizard?
What happens if you remove both serial ports from Device Manager, reboot, detect hardware (with the mouse plugged in)?
Aaron Cake
London, Ontario, Canada
Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Win95 Kernal w/Custom Player
Car: '86 Mazda RX-7 w/Basic Performance Upgrades
Try the mouse in dos.
(ie use the disk that came with the mouse mouse.com and see if get a mouse cursor in texteditor)
Also check the BIOS settings to make sure that irda hasn't been enabled
Sproggy http://www.sproggy.com
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
