Results 1 to 4 of 4
Thread: Help.. my CD keeps skipping
    Apr 2000
    Arroyo Grande, CA
    Post Help.. my CD keeps skipping
    6 months ago I installed a BookPC in my Eclipse to use as a headunit. Once I got the initial bugs worked out, it worked great up until a couple of weeks ago when all my CDs started skipping. Currently, the only thing on the harddrive is Win95 and Winamp. All the music is burned onto CD.
    The thing is, the CD doesn't skip only when I hit bumps. I could be crusing down the freeway at a smooth, regular speed and it will still skip. When it does skip, it's not like a regular CD player where the music will continue after a couple of seconds. It happens like a broken record, repeating the same second of music over and over again. During this time I can't do anything but power the computer off (winamp is frozen).
    Could this be the sign of a failing CD-Rom?
    Thanks,
    Marlin Liew http://phacadeaudio.cjb.net
    Feb 2000
    hoppers crossing, victoria, australia
    Post
    try pre buffering the tracks into memory
    only takes like 2-3 seconds between tracks
    cheers
    pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Jul 2000
    NA
    Thumbs up
    First, clean the laser using a laser cleaning kit from kmart (it's a CD with little brushes on it)
    Second, if that didn't work, clean it manually.
    If that doesn't work it (the laser) may need changing.
    Not too sure about this so please correct me if I'm wrong.
    Regards,
    Michael
    Apr 2000
    Post
    Any chance that your processor is overheating? Computers will do funny things when that happens. You may want to make sure there are no cables interfering with the fan.
