Results 1 to 10 of 17
Thread: Formatting my additional HD
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I've got an additional HD in my pc, it,s a 30 Gig drive. I allready formatted it. When I check the files on it, it is empty (like it should be). When I check the properties on it, it says: used space 28.3 gigs, and 4.99 free space. How do I "unconditionally" format and empty this drive?:
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Ok i am not sure if you want to format it completly. IF you do Go to control panel. Then to Administrative Tools. next to computer management. THen on the left and side should be disk management click on there. and then just right right click on the drive you want to format and then click format..
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    block size, system files, recycle bin all have their part to play in nibbling away at space.
    from the command prompt, your unconditional format command is:
    FORMAT /U d:
    •Micke
    Jun 2004
    South-Central PA
    @kickercivic, did that, now under properties it says: 0 free and 0 used (space)
    @grepzen, doing that now, says: verifying 5145 Mb ..% formatting.
    Now the formatting is complete: says: 5269288 total space and 5240516 available.
    Tried what both of u said, check properties and now it says the same as my 1st posted picture. I don't get it, u can see that it's a 30 gig drive. Any other ideas?
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Firmware upgrade possibly?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    forgot how i did it. either i used a boot disk and formated the drive or right click format(if there is one) or command prompt, format drive.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by muldrick
    I can't see that. Looks like a 5 gig drive to me, with 28.3 megs taken and 4.99 gigs free.
    Jul 2004
    VaBch VA
    is it a 30g drive with only a 5g partition?
    •Micke
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    how big is your primary drive and how old is your motherboard? also check the jumpers on the drive sometimes they have a special jumper that limits the size
    Quote Originally Posted by grepzen
    or like he said, you just have a very small partition on it, you should be able to see how big the drive is and how big the partition is by going to disk management under computer management
    肚子笑痛了
    S60 Install
    Jun 2004
    South-Central PA
    @jjh: I might do that, disconnect the master, put in a boot and format it that way.
    @Rob: yeah, I see that now, I "know" this is a 30Gig. This is the drive that came on this HP, bought about 2 years ago. I filled it up, so about I bought a 60Gig which is now my primary/master drive. I used this second drive as a backup device. I'm gonna take it out now and check it.
    Thanks for all your help, I'll let ya know what happens...
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. epia m1000 nehmiah + laptop HD problems
    By chicochu in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:15 PM
  3. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  4. Why does my HD stops???
    By nl4jy in forum General Hardware Discussion
    Last Post: 02-05-2004, 11:53 AM
  5. Dying HD?
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 03-07-2002, 10:47 PM
