Results 1 to 8 of 8
Thread: Pentium M Mini-ITX mobo with AGP slot !!!
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Exclamation Pentium M Mini-ITX mobo with AGP slot !!!
    http://www.kontron.com/products/pdpr...eySiteRegion=7
    LVDS, LAN, 4x USB and 4x COM, 1x AGP/DVO, 1x PCI
    # Intel® Pentium® M and Intel® Celeron® M Processors
    # Front Side Bus 400 MHz
    # Intel® 855GME + Intel® 6300ESB Embedded Chipset
    # Intel® Extreme Graphics 2 Controller
    # Flat Panel Display Support
    # Dual independent Display Support (incl. 2x LCD)
    # Up to 1GB PC2700/DDR333 SDRAM (incl. ECC)
    # 3x 10/100/1000 Mbps Ethernet
    # 4x USB 2.0, 4x RS232C
    # 1x ATA100 and 2x SATA150 IDE Controller
    # AC-3, SPDIF and Sound Blaster 16 compatible
    # Size: 170 x 170 mm (6.7" x 6.7")
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    All I can say is Whoa! I wonder how much this will run...
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    Nov 2004
    Cali
    From what I have seen elsewhere on the web, this cute little baby will run 450-700... yes, american dollars. So figure the super expensive Pentium M processor and you have a choice of a nice computer or just as nice of a car
    But hey, if nothing else, you have enough ethernet ports to network the tires and armrests together.
    Nov 2004
    I would be all over this if the board was cheap, i mean, believe it or not, you can grab a celeron M chip for only like $150, and they are only a few ticks slower than the Pentium M according to all the benchmarks. Just not worth it though to spend all that money on a motherboard thats just being used in the car. Unless of couse you have money to burn, then what the hell.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    why do you need 3 LAN connectors??? If they did a version with a couple of firewireisntead it would be much better.
    May 2003
    Then how about this.
    Commell LV-672
    Features
    CPU: Intel Pentium 4 with LGA775 @ 800 MHz FSB.
    Memory: 2 x 240 pin DDR2 533MHz up to 2.0GB.
    Chipset: Intel 915G and ICH6R.
    VGA Interface: built-in Intel Graphics Media Accelerator (GMA) 900.
    PCI Express bus: PCI Express x16 graphics delivers up to 4 GB/s per direction, 3.5 times more bandwidth than AGP8X.
    Enhanced IDE: one Channel support 2 ATAPI devices up to Ultra DMA 33/66//100 mode with data transfer rate up to 100MB/s.
    Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 4 ports. Supports RAID 0, 1 and 0+1 function.
    LAN Interface: Two 100Mbps/1Gbps Ethernet port by Intel 82541GI .
    Audio: Realtek ALC655 AC97 3D audio interface.
    USB: 6 Hi-Speed USB 2.0 interface with up to 480 Mbps of data transfer rate.
    IEEE 1394: 2 IEEE1394A ports with 400Mb/s transfer rate.
    I/O Ports: 2 serial ports, IrDA, FDD, PS/2 keyboard and mouse ports.
    Mini-PCI: 1 x Mini-PCI Type-III socket.
    Digital I/O: Supports 8 bit digital I/O.
    Watchdog: Software configurable, 1s.....255s / 1ms.....255 ms.
    You can get it here: http://www.bwi.com/scripts/site/site...ion/configure/
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by lars46
    Commell LV-672
    SNIP
    Sure $350 for the board,.... no way.
    TruckinMP3
    Read the FAQ!
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by Seth
    Just seen it on epiacenter.com
    From the specs it doesn't have any rivals...
    It has, and for the forst time, a 4x AGP port. It also has 2 ddr slots. Still 1 PCI slot though. I think I'd rather have 2 PCI ports, than 2 ddr slots.
    Anyway, far better that the Commell.
  1. Mini ITX in car stereo?
    By ljstevens in forum Newbie
    Last Post: 11-26-2004, 10:56 AM
  2. micro atx and mini itx case
    By dannn in forum General Hardware Discussion
    Last Post: 11-01-2004, 09:04 PM
  3. best mini itx board
    By 2nau-t in forum General Hardware Discussion
    Last Post: 09-08-2004, 10:05 PM
  4. What case to get and where? for an ASUS Mini ITX mobo? not a DIY case.
    By BEHMER in forum General Hardware Discussion
    Last Post: 07-31-2004, 09:01 PM
  5. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 08:46 PM
