Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: can i connect my xbox to my car amp??
  1. #11
    bakersfield, ca
    audio control matrix will jack up the pre out voltage to 9.5v rms, but this is more than most amps will take, i have mine set at 7v, and it was like night and day when i installed it. Its only like $150 for 6 channels. Awesome piece of hardware.
  2. #12
    Nov 2004
    Quote Originally Posted by MegatronUK
    My previous setup used an Xbox......
    Xbox composite video -> Headunit
    Xbox L audio -> Headunit
    Xbox R audio -> Headunit
    Headunit front audio-> External Amp -> Component front Speakers
    Headunit rear audio-> Headunit Amp -> Factory rear Speakers
    Worked fine.
    Can you explain why you would hook up your video composite to your head unit? Does your HU have a vid screen that accepts input?
  3. #13
    Newbie MiniRX7's Avatar
    Aug 2003
    Toronto
    I think you misunderstood..
    I have the same setup as Megatron, where my xbox connects to AUX in on the deck then to the amp.
    What i am saying is that it will sound horrible and you will ahve no volume control without something between the amp and the xbox (IE. EQ, deck or something)
    2k3 Max SE 6spd
    Temp setup:
    7" indash screen/Xbox running XBMC
    Carputer coming soon
    My 2003 Maxima
  4. #14
    Nov 2008
    Headunits Speaker Splits PLZ HELP!!!
    can anyone help?? I have a Pioneer DEH-P7000UB. being a student i cudn't afford to buy a sub and amp to make my car pump... therefore i took some old household speakers from my old hi-fi system and wired them up to my car... splitting the rear speakers with the hi-fi speakers ideally it sounds a lot better and does kick... however a mate of mine told me if i left it like this sooner or later it will fry the headunit... is this true? and what are alternatives?? plzzzzzzz HELP!
  5. #15
    Jun 2008
    Seattle, WA
    Home speakers are usually 8 ohm. Car speakers are usually 4 ohm. By wiring them up in parallel, you are presenting a load of about 2.67 ohms to your headunit. Most headunits aren't rated to go lower than 4 ohms. Yes you could damage your headunit if you leave it this way.
    Plus I doubt that the 22 watts RMS per channel that your HU is putting out is going to make your car "kick". Search ebay, craigslist, and local pawn shops for a decent amp. And remember, when shopping amps, compare RMS wattage ratings, not peak ratings, which are mostly meaningless.
    If you want cheap, by far the best way to get great sound in your ride is to follow in the footsteps of this guy: http://www.newcougar.org/forums/vide...ut-cougar.html
    (Sorry, that thread just never gets old!)
  6. #16
    Elsewhere
    1 - Threadjacking is bad. (Threadjacking is tacking onto an existing thread with nothing useful or straying off the original thread topic.)
    2 - Threadjacking a four year old thread willg et you ridiculed mercilessly.
    3 - This query really belongs in the Car Audio subforum.
    How about the Wiki?
  7. #17
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    See DP, now don't you feel all helpless without your super powers?
    In days gone by you would just have split the thread, and given rizzla0 a clip round the ear (AKA Infraction) and gone and poured another coffee.
  1. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  2. S.M.A.R.T. car
    By link138 in forum Newbie
    Last Post: 11-12-2004, 10:14 AM
  3. car amp power supply
    By fuctup in forum Power Supplies
    Last Post: 11-03-2004, 02:52 PM
  4. Replies: 1
    Last Post: 07-28-2004, 11:26 AM
  5. Replies: 6
    Last Post: 08-06-2001, 03:58 PM
