Results 1 to 7 of 7
Thread: possible ??
    Low Bitrate TechToy's Avatar
    possible ??
    I'm planning to pull the factory radio and use the car-pc as the head unit... i know no biggie... but is it possible to actully push the outputs from the car-pc directly into a power amp. ?? based on my thinking it shouldn't be a broblem.. but would love the forum's opinion..
    i'm planning on using the ICOM IC-PCR1000 for the main raido, eliminating the need for the scanner AND the am/fm radio (too bad it dosn't transmit)
    external radio -> carpc -> 4channel amp -> spkrs
    (line level) -> (line level )->(same)->spkr level
    12v line from the car-pc energizing a small relay to turn on the amp, i know i shouldn't need the relay.. but i'd rather it for isolation ...
    anybody see any issues or problems with this setup ??
    TechToy
    2005 Explorer
    Proudly using Centrafuse
    DWW-700M + Sony XM-SD46S &
    pre-amp, XM100D
    and Icom PC1000
    Yaesu 7100M
    Kenwood TM-641
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    this is what most people do (well what pretty much everyone does if they dont use a headunit)
    to turn your amp on put the relays coil on your computer psu, and the wire from your ignition/acc through the relays switch, this eliminates the speaker "pop" when your computer turns on, your amp will be on whenever your key is in the igniton/acc position AND the computer is on
    Signature: [==||========] 20% complete
    Dec 2003
    SoCal - 909
    I bought this little gem: http://www.audiocontrol.com/MobileAu...nDash/HPX.html
    I've been doing high end audio in my car for many years now so I wanted some serious stuff to control the audio side of the PC. I get to have 13V preouts to my amps. This is probably a bit overkill for most amps, but my old eclipse HU had the same max and RMS specs and my amps loved it. Nice clean transfer of music from the front of the car to the amps in the rear. Plus, I get a volume knob and a sub control knob which are 10x more convienient that messing with it on the PC. the additional source input was a nice bit of frosting on the cake as well. It will set you back about $250-$300 though
    AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
    MediaEngine front end, map monkey, netstumbler.
    gps mouse is on the fritz.....stupid technology
    Jun 2003
    Chicago
    Quote Originally Posted by Cryogen97
    I use a Clarion Eq with main/sub volume control similar to this unit...
    http://cgi.ebay.com/ws/eBayISAPI.dll...734671727&rd=1
    Dec 2003
    SoCal - 909
    yeah, something at that level is going to be a lot accessable to non audio snobs and still get the job done.
    Variable Bitrate Dracos's Avatar
    United Kingdom
    i do believe he was asking about having his headunit going INTO his CPC - rather than CPC INTO HU. And, as n00bish as this is gonna sound, I havent ever seen it done, heard of it done or thought about doing it - but I will say, its a damn good idea imo.
    I actually have the correct connectors for hu speaker line -> RCA converter, and RCA -> 3.5mm Jack -> into PC. hrmmm. that way i can get rid of my TV card which is a bastard and dont work with radiator, and therefore, frodo. (also, the app that comes with it isnt very smallscreen friendly).
    thanks guys...
    I like the idea of the 1/2 din "controller" I was just dreading running all that wire again... pulled just under 100lbs of wire from the last truck... and i promised myself i asn't gonna do the same ...
    here i go again... getting sucked in again...
    thanks again.. my mind was clouded by the dark side... now i see clearly
    once this ones complete will post specs and pics...
    eventually want to hit one of the NY/NJ meets...
    TechToy
    2005 Explorer
    pre-amp, XM100D
    and Icom PC1000
    Yaesu 7100M
    Kenwood TM-641
