Results 1 to 10 of 11
Thread: NO Sound w/ M10K [HELP]
    Jan 2004
    NYC
    Ok I was just about ready to install this board into my car and wanted to test my onborad sound first using my desktop speakers[2 speakers]
    Plugged in the plug to the "line out" and nothing........i get a weird hissing noise and when i move my mouse it makes it even worse
    Im using the latest drivers from EPIA Found Here I also tried the ones on the CD and still no luck.
    I set the audio properties to "desktop speakers"made sure nothing was muted/low in the volume properties
    Like I said Im only using this[desktop speakers] to test to make sure my sound is working. When In my car, I have a 4.1 setup using a 5CH AMP
    Any Ideas Guys.............thanks
    Oct 2004
    Australia
    You prolly want to plug it into 'line out' to get sound out to your speakers.
    Jan 2004
    NYC
    Quote Originally Posted by Gibbon
    yea thats what I meant to say, sorry.......I edited it above
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Have you verified that the speakers work properly with line-level output from another computer? You might also try a pair of headphones.
    Jan 2004
    NYC
    Quote Originally Posted by Change
    Yea, The speakers im trying are from my desktop PC - they work fine
    I also tried headphone with no luck, just makes a loud hiss noise
    Can it be a defective board
    Anybody have any other ideas - Im ready to throw this thing out the window
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Is the AC97 Sound turned on in the BIOS? Did you check to make sure the lines are not muted in the sound properties...
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Jan 2004
    NYC
    Quote Originally Posted by judoGTI
    Yea in the bios it only has a option for "auto" & "disable" - it is currently on auto
    As far as the the lines being on mute - i check all that, i even just unchecked all then just to make sure
    judo,what audio drivers are you using, did you have to do anything differently to setup this audio
    this sucks I spent 2 full days doing the installing[running wires,amp,etc..] in my car, now I have this stupid issue holding me up
    Feb 2004
    Florida
    Nope, mine worked right away. But I doubt its faulty. What does the device manager say?
    '02 GTI
    Jan 2004
    NYC
    The device manager is good,no conflicts - all drivers are installed
    When I get home Ill check what drivers are installed - and campare them to yours
    Also At first I had the front audio cables setup with my c134 case - I had to remove 2 jumpers - I still got no sound with the front audio cables, i then put the jumpers back and removed the front audio cable - NO LUCK
    Constant Bitrate asci01's Avatar
    Jun 2004
    Florida
    I'm sorry about your frustration. I almost gave up with the project when I first received a dead mobo, a PS with a design flow that blew up and almost caught fire, and a hard drive that died after I had installed all the software, drivers, etc.
    I didn't change any jumpers either. I used the default settings.
    It looks like people already suggested the things I was going to suggest except:
    Try testing the microphone and line in and see if you get any sound in.
    I also sent you a PM on CL
  1. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 02:05 AM
  2. sound question m10k vs. audigy?
    By ashzero in forum General Hardware Discussion
    Last Post: 08-30-2004, 05:40 PM
  3. cant get epia m10k to output sound
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 06-11-2004, 09:02 PM
  4. EPIA M10K Sound and 4 chan amp
    By bklynkaos in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:26 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 09:01 AM
