Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Auto Engine Start without A PC
  1. #21
    Constant Bitrate SuzukiAerio's Avatar
    Aug 2004
    PA, USA
    Exclamation
    Quote Originally Posted by lostreception
    range isnt the problem its timing
    I want it to go on automatically each night around 9 or so
    how might I accomplish this ?
    My car starter will auto start my car with out me needing to be in 'range" or having to do anything ....
    There are a few of them out there ...mine is a Avital ..
    The mother company that makes it is called Directed
    It got a LCD keychain..... I have had it for alost a year now with minimal problems
    $350 installed
    2002 Suzuki Aerio Sedan ...NOT the stupid wagon
  2. #22
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Remote starts using "tach sense" look for a voltage level to be reached on the tachometer wire. The wire uses AC current, not DC. When that range of voltage is reached, it ceases to crank. This also allows you to press your remote start button when the car is already started and then remove the key and leave the car running when you want to run in somewhere. I worked at the local stereo shop for almost 2 years and installed several alarms/remote starts.
    ATVMS.com
  3. #23
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    I've got a pager alarm. It uses RPM sense, it's got a wire that taps into the coil. In order to duplicate that by a DIY circuit, you'd need to measure the pulses from the coil and shuts it off when it reaches over ~500 RPM. Lots more work than it should be. You'll probably also need to power the ignition circuit as well as the starter itself, in order for it to start.
    Also, my alarm has two choices for unmanned remote start. One is auto-start every hour to four hours, for a 24 hour period, or when the temp drops below a set temp. My alarm also has an input trigger wire for the remote start. If I supply power to the trigger wire, it'll automatically start the vehicle.
    Good luck,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
  4. #24
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by SuzukiAerio
    $350 installed
    I see there i a clock on the lcd so u can set it to a time to turn on?... my
    remote start is a Avital but i doubt theres an upgrade option :-/
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  2. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  3. Inverter not booting pc after second try
    By ChrisC in forum Power Supplies
    Last Post: 11-12-2004, 10:51 PM
  4. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 02:04 PM
  5. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 12:49 AM
