Results 1 to 10 of 11
Thread: Laptop HD, password encrypted - break it?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Laptop HD, password protected - break it?
    Ok, I know this will probably sound really bad, and I'll probably get yelled at for it.... But for those of you who don't want to flame me for this here's the story:
    My friend at work had some problems with his original hard, so he got a replacement under warranty. No problems. They sent him a new one.
    He tries to install it, and gets some warning that the hard drive is password protected. He tries to get them to send him a new one, but they say its the laptop, not the hard drive. He has graduated from (I think) 3 different IT associate programs, he knows what he is talking about.
    He bought a new drive, and intalled it himself, everything is fine. He gave me the drive that was giving him the problem. I would love to use this drive in an external enclosure for some portable media.
    Is there any program or hardware solution to this? I'm not looking for the external enclosure, thats easy. I'm looking for a way to get past this password protection. Now, I haven't even hooked it up yet. I am hoping someone could point me in the right direction first, then I'll get the enclosure and worry about that.
    And, yes. I know what it sounds like. If you know of a solution PM or me post it here. If you don't trust me, I completely understand. Just don't post your "You shouldn't be doing this" here, please.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Aug 2004
    California
    Try a low level format. That should get rid of everything on the drive and then you don't need to worry about recovering information you should not be looking at.
    Feb 2004
    PA, USA
    Quote Originally Posted by voidunknown
    See, there shouldn't even be information on the drive, at this point. It is suposed to be a brand new drive. Now, when you say low-level format, just fo into Windows, and format the drive?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Mac Car Moderator kandyman676's Avatar
    Maryland
    exactly was going to be my solution voidunknown. :-P
    stick it in an external enclosure or another laptop, and format it with some bootable linux distro since most do a low level format. I *think* even a bootable WinXP disk can do it as long as you do not do the quick format option.
    that should remove any protection the drive has, and destroy any data the drive has.
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    actually I think you can only low level format in the bios... I doubt Linux distros low level because there is potential to permanetly damage te drive.
    Kimi ga kawareba, Seikaimo kawaru!
    Aug 2004
    California
    No no no. Alright let me explain this a bit...
    When you format from a Windows or Linux CD it does a HIGH level format. Most people just call this a "Format." It simply erases the contents of the drive and/or removes the "Table of contents" from the drive (quick format). This process can take just a matter of seconds/minutes.
    A low level format is what is done by every hard drive manufacturer before a hard drive is boxed and sold. A low level format will rid the hard drive of bad sectors (so to speak). It makes it impossible to recover any info from the drive because it completely fills the drive with "useless" information. It also sets certain properties of the disk such as the interleave factor. A low level format also determines what type of disk controller can access the disk. It can/will also take several HOURS to complete this type of format. A low level format UTILITY can be downloaded from the website of the hard drive manufacturer. If you have a maxtor hard drive, DO NOT use a Seagate low level format utility. Your drive WILL be useless.
    Aug 2004
    California
    Quote Originally Posted by got2liv4him
    No, you can boot from disk and low level format, I do it all the time. Yes, some BIOS' do have a low level format option (the older ones) but it is not recomended that you use that one. Get the one from the manufacturer of the drive.
    Also, he hit the nail on the head. IF NOT DONE RIGHT A LOW LEVEL FORMAT CAN DAMAGE YOUR HARD DRIVE! BE CAREFUL!
    Maryland
    you are right voidunknown. I was confusing the low level programs with linux, but they were actually old DOS programs, like the one Western Digital has.
    this site has a list of them:
    http://www.ariolic.com/activesmart/l...el-format.html
    also you can use some other utilities to write zeros to the whole drive to completely wipe it clean:
    in DOS: http://www.killdisk.com/
    in linux: http://www.linuxgazette.com/issue37/tag/38.html
    Aug 2004
    California
    Quote Originally Posted by kandyman676
    Yes, but those last 2 programs will not perform a low level format. In order to get rid of the encryption on the drive so that he CAN write zeros to the drive, he will need a low level format. Period. As long as the drive detects in the BIOS when booting, a low level format can be performed.
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    1) Buy screwdriver
    2) Buy magnet
    3) Open drive
    4) Play with magnet
    5) Close said drive
    Quick! To the Popemobile!
  1. Laptop HD issue...??
    By ApoloV in forum General Hardware Discussion
    Last Post: 12-23-2004, 08:59 AM
  2. Microdrive vs. 2.5" laptop HD
    By videonerd in forum General Hardware Discussion
    Last Post: 11-14-2004, 01:09 AM
  3. Need Desktop HD to laptop Mobo Connector
    By Joe_Collectible in forum General Hardware Discussion
    Last Post: 09-26-2004, 09:38 PM
  4. epia m1000 nehmiah + laptop HD problems
    By chicochu in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:15 PM
  5. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
