Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Does The Cold Affect System?
    Feb 2004
    Bay Area
    hi people, i have my system installed for a couple of months now. and its been working fine (besides the point that my hard drive crashed, but its just easy replacement so no worries) anyway, my problems are starting now.... just yesterday my carputer started to restart on its own... it would do it over and over again. plus my touchscreen isnt working also. i was thinking the computer had a problem so i took it out and ran it at home and it works flawlessly. i was wondering since weather is getting chilly over here (35F) i was thinking this may be causing it. btw, my ITPS is exposed and not inside my case. its actually mounted to my trunk. does the cold affect this? if not... whats may be causing my problems?
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    Check the manufactures operating specs on the LCD and the hard drive. I know the LCD's have issues in extreme cold but I would bet the hard drive was the cause since it was only down to 35 F.
    I would also bypass the ITPS for testing purpose if it happens again. Could be something simple like the cold HD demanding too many amps to spin up and the ITPS voltage regulator peaking out. I have seen the same thing while testing with a questionable 3.5 hard drive, CD and a floppy drive all powered through the ITPS. I bypassed the ITPS and stopped it.
    May 2004
    NY State USA
    I have a CRT monter that has trouble starting up in the cold, and the picture is a little dark for a while (most likely due to less pressure in the tube). I know motherboards and processors can opperate at cold tempatures, but i am a little worried about my hard drive. (I think most Rf hardware wont function past freezing.) Does anyone know the limites of hard drive tempatures? In my area it could get well below freezing. Thanks.
    New car means time for a new carputer.
    Planing.
    FLAC jbors's Avatar
    Nov 2003
    Mobo( VIA ) 0C - +50C
    PW-70 -40C - +90C
    ITPS -20C - +125C
    It could be either your weak battery or mobo. Which power adapter are you using ? And what's you components ?
    Car pc integration with ease
    Car mediacenter
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    It was 20F when i left for work this morning, and this drive to work was the best that the carputer has worked in weeks Hard drive is mounted vertically on my sub box in the trunk.
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    Quote Originally Posted by trebuchetguy
    correct me if I'm wrong because I'm not an expert on everything (don't let my girlfriend know) but i wouldn't think this would be because of low pressure in the tube. in general cold air would be causing higher pressure wouldn't it? that and aren't crt tubes vacuums for the most part?
    don't worry i know i usually don't make much sense
    Nov 2004
    Is it mounted in the trunk? Are you booting up after the car warms up?
    Super Moderator xBrady's Avatar
    USA
    Sounds like a power issue to me with your computer reseting.
    Don't know about your screen.
    Been in the 20s all week and my HD hasn't had a single problem.
    Installed.
    -GPSSecure- - GPS Tracking
    Low Bitrate khemical's Avatar
    Jun 2004
    DeKalb
    This is why I keep thinking I should keep my headunit (and mp3 filled cd's) or keep my car dock for my sirius radio in my car...
    steve
    USA
    Quote Originally Posted by khemical
    steve
    Why? Because of the cold?
    Installed.
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-17-2004, 12:38 AM
  3. Does cold affect boot time?
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 02-13-2004, 02:33 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
