Results 1 to 10 of 11
Thread: Powering Devices?
    Jun 2004
    Winnipeg, Canada
    Powering Devices?
    I just bought a USB hub that I want to put in the glovebox. It comes with an AC adapter that says its 5v. And I'm going to buy a DVD drive that I want to mount up front that apparantly operates on 5v (http://www.pcalchemy.com/product_inf...products_id/44). Whats the best way to power these devices in the car. The power wires in the car are 12-14v, do I have to run a 5v wire all the way from the computer power supply in the trunk to the front of the car???
    Tainted Love Cris's Avatar
    Romania
    Yes you have to run a stable 5V from the PSU. You hook a wire up to the 5V line, and a wire to gnd from you molex connectors.
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Quote Originally Posted by Optikal
    I used a cigarette lighter plug.
    Hardwired 3-port cigarrete lighter adapter.
    It works fine.
    Jun 2004
    Winnipeg, Canada
    What do you mean you used a cigarette lighter plug? Did your usb hub/dvd-drive come with cigarette adapters? Isn't the cigarette power supply 12v? if so how did you step it down to the 5v these devices need?
    Nov 2003
    TN
    Something like this.
    This is not the exact model, but you get the picture.
    RadioShack has several different types.
    FLAC jbors's Avatar
    Nov 2003
    PW-70 has extra wire for +5V output. Anyway it should go from the PSU, not from the car directly.
    Car pc integration with ease
    Car mediacenter
    Jan 2004
    Jersey/NY
    there's some chip that people use on these forums.. i forget the name, but i'm sure if you search you'll find... it just does what that radioshack thing does basically, without the cig lighter plug (which I don't think you want or need anyways).
    So search for it... only a couple of bucks, and should be good enough for what you want.
    Jan 2004
    Jersey/NY
    eh I got bored, so I did the search for you
    powering usb hub
    check that bottom post by 4u2n
    Nov 2003
    TN
    Quote Originally Posted by wizawuza
    ... without the cig lighter plug (which I don't think you want or need anyways).....
    Are there some issues with using cig lighter plug?
    Is that bad for the device?
    Jan 2004
    Jersey/NY
    Quote Originally Posted by ryuandwings
    I'm sorry I didn't mean it like that.. just since he's putting a hub into his glove compartment, he wouldn't want to have a wire going into the glove compartment like that. It'd just look so much nicer by tapping into a wire near there (or ideally going directly to the fuseblock). Purely aesthetics.
  1. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 04:19 AM
  2. 2 pointing devices
    By turbochris in forum Input Devices
    Last Post: 09-14-2004, 09:09 PM
  3. powering various devices
    By suprthug8d in forum Power Supplies
    Last Post: 06-18-2004, 09:32 PM
  4. powering some usb devices
    By cubanmoses in forum General Hardware Discussion
    Last Post: 10-08-2003, 12:23 PM
  5. Can we get a forum devoted to input devices?
    By CA 3000GT in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-27-2003, 03:40 AM
