Results 1 to 10 of 14
Thread: Pentuim M on DFI Vs. Epia Worth it?
    FLAC alti's Avatar
    NY
    I have a conundrum. I have been delaying the install of my carputer waiting to save up for the right parts since august now. I finally purchased an Opus 150, Seagate HD, Panasonic slot load DVD/CDRW and Kingston 512 DDR. I already have my GPS, OBD and my albrite/controller/inverter, (which is a long story and for another thread, but going on the assumption that everything works out with the screen, I am almost there.)
    I still have to buy a motherboard. For months I was under the assumption that I was going to buy an M or MII epia, but kept holding off from purchasing it. I wanted to, but kept holding myself back. While I am sure that the epia is the smart choice for power consumption, size, low heat output, price and port availability. I also know from what I have read here that they are not the fastest boards either. I am not a gamer so I just assumed it would be enough for my needs in the car, and chalked it up to the sacrifice for the low power consumption.
    Then a couple of weeks ago came this
    And this was already around but the only board available was a super expensive ITX option that was way out of my league.
    But combined with one of the two new mATX boards it is under $500 dollars
    Hmmmm.
    So my question is who thinks it is worth it? There is a good 250-300 dollar difference between the epia and the Pentium M setup.
    The Pentium M 2.0 only consumes 28 watts at full load, I am sure the 1.6 will be slightly less, I cannot find info on how much power the DFI consumes only that it is listed on there site as “low power”. Form what I have been reading DFI makes a good board and a overclockers dream. I few reviews have overclocked the 2.0 M to 2.8
    I am especially curious to here from Epia owners in a “if I could go back and do it again light”. Knowing what you know now having had the epia what’s you take? If I decide to go with the Pentium setup it is going to delay my install yet again.
    Sorry this is so long.
    Thoughts
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why not AMD Athlon Mobile?
    My combination cost about 190 (CPU 100, Asus mobo 75, + Tax S/H)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    MatrixPC, I was thinking about switching from my EPIA 800 to an athlon mobile setup. What model motherboard are you using?
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I have the same setup as MatrixPC, Asus A7N8X-VM motherboard with a Mobile Athlon 2400. For me it cost less than MatrixPC, I was able to find the board for about $40.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by bjm2020
    Read below !
    FLAC alti's Avatar
    NY
    I will look into the athlon idea... anyone running it with a opus?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Banned
    Feb 2004
    You can you a 35watt Mobile AMD 2500+ at 1800+ (1.1volts) and it will use 25 watts of power. Plus these chips are MUCH MUCH cheaper than the Intels.
    My main right is a highly overclocked (watercooled) Mobile AthlonXP 2500+ running at 2.85GHz (~3800+) (as fast as a 3.88GHz Pentium4) 2.2volts. When I underclock it alot, I am able to run it at 0.8volts at 900MHz, and it uses about 16 watts.
    Here's a link to a 2400+ Mobile (35watt). http://www.newegg.com/app/ViewProduc...103-439&depa=0
    Underclocking it would be a very effective (and cheaper) solution.
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    athlon Mobile suggestion seconded. Excellent processors and very robust. They come multiplier unlocked so you can give yourself a wide range of performance options. My desktop is running at 2.4ghz, but i've also run it all the way down to under 1ghz. In fact, if you use speedfan on a supported motherboard, it'll change your clockspeed on the fly, kinda like speedstepping for your car computer or desktop.
    Best of all, they work on a lot of existing socket platforms.
    Just make sure you get a mobo that supports undervolting; this'll help you run a lot cooler.
    Jun 2003
    Chicago
    Quote Originally Posted by Quattro-A4
    Where did you get the mobo from?
    Dec 2003
    New York
    Quote Originally Posted by EBJUSTIN
    www.dumpinggoods.com
    Installed
  1. BEWARE: Epia V8000 & Opus 90W combination
    By Jailer in forum General Hardware Discussion
    Last Post: 12-28-2004, 08:57 AM
  2. VIA EPIA Motherboards - Which one is this???
    By pyros in forum General Hardware Discussion
    Last Post: 03-12-2004, 12:15 PM
  3. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  4. VIA EPIA M Sound quality
    By Mafri in forum General Hardware Discussion
    Last Post: 01-11-2003, 04:55 PM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
