Just wire it with a relay to the door lock pulse.
- From power source/always hot (battery) to terminal 85 and 30
- From door switch (- pulse) to terminal 86
- Terminal 87 connect to SDC ignition signal and the real ignition signal. Isolate the 2 sources with diodes like this
---- Relay 87 --- DIODE ---| SDC IGN
---- Car ING ---- DIODE ---| SDC IGN.
[edit] Of course, you must fuse all power sources [/edit]
LinkBack URL
About LinkBacks
