Results 1 to 7 of 7
Thread: Light sensor
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Question Light sensor
    I get an idea maybe I’m crazy,
    Automatic light sensor to control the light in the consol and maybe the gamma on the TFT screen
    Then the problem cam, where to put the sensor, because the sensor most only see the daylight not light from lamp on the road or other car.
    Some Idea to put the sensor and how
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Dec 2003
    place one sensor looking outside through the window and the other in the dash. Then have the sensor compare the light input from outside to light input from inside. Then write a program to adjust the light output on the screen to adjust accordingly.
    May 2004
    Denmark
    Quote Originally Posted by Tred
    how to tell the sensor looking outside it daylight og light from another car. ????
    Ditail at 4u2n.dk
    Here
    Low Bitrate gadget's Avatar
    May 2004
    Colorado
    I would like to see that. Don't know how it would work or anything. Could you just have it located like near the lower section of the dash? Ambient light would be fairly consistant, and you would not get headlights or anything in that location. I am thinking like under and a little in front of the glovebox looking toward the passenger side floor mat.
    It would be nice to then somehow set the skin for your front end and change the settings for the screen.
    I am a newbie trying to outfit a couple cars with new custom consoles and mini ITX. Click here for my 2003 Chevy Avalanche project.
    Low Bitrate modUlarBeing's Avatar
    Aug 2004
    I was thinking about doing this at some point. but the way that I understand in cars that come with light sensors to control headlights there is a delay on it. This is to prevent street lights, other cars headlights, etc from triggering it. So basically you would monitor the sensor for a couple minutes and after that if there is no change then do whatever you need to do.
    btw, most manufacturers place this sensor on the dash near or in the defrost vent.
    Nov 2004
    Cali
    Quote Originally Posted by 4u2n
    Actually it is not so hard, despite what it seems to us as basically the same brightness (car lights or day lights) in fact they vary in brightness by order of magnitudes, our eye doesn't see that because it has logarithmic scale.
    So with a circuit, correctly calibrated, it should not have any trouble distinguishing the two instances.
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    Personally, I'd like to have the gamma adjust and the player change to a night skin when I tell it to by flipping a switch or press a soft button. I'm sure this is possible but I have no idea how to do it.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 03:03 PM
  2. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 10:54 PM
  3. Painting a reverse / parking sensor?
    By modemide in forum General Hardware Discussion
    Last Post: 09-06-2004, 08:05 PM
  4. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 11:19 AM
  5. sensor
    By llmask in forum General MP3Car Discussion
    Last Post: 03-21-2004, 09:10 PM
