Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Computer Crashes When I hit a bump
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    So I had the first long road test of my carputer the last couple of days. I went to Lake Tahoe for a snowboarding excursion.
    On the way back the computer crashed 3 times becasue of bumpy roads.
    What happens is that the screen goes blank and the the music stops. It appears that the motherboard is still running becasue all fans are running but the only thing i can do to get it up and running is reboot.
    My computer is in the glove box. My hard Drive is mounted vertically. Is there anything i can do to eliminate the crashes.
    Tainted Love Cris's Avatar
    Romania
    Crimson, post your setup... Sounds more like a hdd problem...although it shoudn't be. Is it sufficiently ventilated? Describe the bumpes in the road...
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I had th same problem. Check your HDD connections.
    Mine used to disconnect and crash on bumps.
    You might have a bad wire in your HDD cable somewhere, replace the cable and see if it still crashes.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    I had a similar problem on my first carPC attempt. My HD was mounted horizontally. I know you're not supposed to do that, but I already made the case before I learned. Anyways... I tried it out in the car and my CarPC was located RIGHT over the rear axle. Hard bumps were jolting the solid axle pretty hard and transmitting straight to the carPC.
    I ended up putting foam pads between the hard drive and my case to cushion the 'shock'. Since then, I haven't had any more crashes. I will be moving my carPC to a less 'shocking' location.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    although it is possible the hard drive is the problem, dont limit your self to the idea;{since the computer didnt restart, its not other wireing problems}, its still very possible its a power problem, or a wire to another device, or as simple as a PCI card bumping loose for the moment... Just saying check EVERY-THING, wiggle everything with it on, if its not the harddrive then wiggling everything will find it, if it is the harddrive try flicking it with your finger (in center & at the connector), do all this until you reproduce the problem, and you will only then REALLY know what is going on...
    **My 2 cents**
    chuck
    www.XionElectronics.com
    **MY NEW STORE** Come Visit
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    What he said.
    I had the same problem with mine, because of a loose power connector. I'm using an external hard drive, and whenever I would hit a bump the power connector would fall out. Some firm jamming, and some filing and it fit much better.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    Try mounting the drive "correctly" with this stuff.
    Kyosho Vibration Mounting Gel
    I used it in my PC to mount my CF microdrive, first used it on my RC helicopter to mount the gyro which is more sensitve then a HD. It is a sticky gel compound that eliminates vibration for sensitive electronics. All I can say is it works great, how much shock it will absorb I can't say, but it should help you.
    Nos
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Check all the connections for power and data (HD cables) also and cards (PCI/AGP).
    My bet is on a loose or wiggly connections or maybe heat build up (less likely)
    The orientation of the HD does not matter, mount it solidly and forget it.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    The same prob happened to a friend. He had the home pc on top of his sub, and sometimes the screen would go blank. The power supply fans kept going and we could still hear some "activity" inside the case. I wiggled the power wires going to the hard drive and the pc came back to life. We tightened the connector pins and so far so good.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    Whenever my carputer does exactly that (screen/music freezes, puter is still running) it was because a bump knocked my damn audigy pci card out again. Happens quite a bit, my puter is laying in my trunk screwed to a piece of plywood
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 03:14 PM
  3. Building a computer
    By andrew8485 in forum General Hardware Discussion
    Last Post: 05-31-2003, 03:45 PM
  4. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:37 AM
  5. wondering if ur dvd,cdrom, hd skip when you drive and hit a bump??
    By BobyYoo in forum General MP3Car Discussion
    Last Post: 11-29-2000, 02:41 PM
