Results 1 to 10 of 19
Thread: window tint on lcd?
    Nov 2004
    Question window tint on lcd?
    I'm unable to adjust the gamma or brightness on my laptops LCD. Has anyone considered purchasing a roll of cheap window tint and cut it down to size and stick it to the lcd? Does anyone see any reason why that will not work?
    thx
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Just wear sunglasses!
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Maybe get a new videocard? Did you try GammaControl?
    Nov 2004
    I did try GammaControl I can't get it to work with my laptops video card. The manufacture doesn't provide w2k drivers which provide gamma control on the driver.
    It's a great program I wish it worked on my setup.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by cash_Money
    What kind of laptop do you have? Find its specs and then download the drivers for that video card. Not all manufacs update their driver pages.
    Nov 2004
    I have a Toshiba Sattallite Pro 470cdt witha Chips on Technologies 6555 chipset. Toshiba never made a w2k driver and the MS drivers do not seem to allow me to do gamma control however period. The original manufacture 'Chips On' has a 2k driver which has a gamma feature in the display properties applet however It simply will not work right my with laptop. =(
    I purchased a 5pk of transparent/colored plastic dividers from Avery which seem to be working well. I'm going to get it cut down and install this weekend.
    Tainted Love Cris's Avatar
    Romania
    Did you try to run one of the front ends around here. These programs have a dimmer. And at one time, there was a program on the mp3car software section (not the forum one), that did just that.
    Help me learn to do my research before I open my big mouth. Serial Thrilla's Avatar
    Dec 2004
    Fl.
    Lightbulb
    Yeah, I agree with Cris. The reason why a lotta' people use MediaEngine http://www.mediaengine.org It has an auto drimmer function, that you can set for whatever time to start or stop. Plus, if you need more than just that, you can also tell to change to a night time type skin (black), that reduces brightness also.
    I'm sure you already tried this, but have you tried using your function brightness and/or contrast keys? Some laptops have software built-in that can control brightness, so maybe you're using that and not realizing you've got hardware brightness control. But assuming you've tried that, try going into your BIOS (restart and go into your laptop's "setup"). I don't know about Toshibas, but some laptops have BIOS options for brightness. If you're laptop's just gotten into a "funk", turning brightness controls on or off might knock it outta' it's funk and give you control back. Now one word on laptops... programs that can "dim" the brightness of the screen like MediaEngine are fine, but most laptops (like Pocket PCs) will still produce the same brightness even with a black screen, due to the way they're backlit. (that's why hardware brightness control is so important to my GPS Pocket PC) Hope this info helps.
    Nov 2004
    I've tried just about everything.. afaik this model only has gamma adjustments in the driver an no function key. The avery transparent colored divder has helped a lot but it's still not dark enough.
    Jul 2002
    omaha NE
    if you can hunt down a red tented plastic it would do the job for you
    FEEL THE RUSH
    P4 1.7, 1gb sdram, 40gb 7200, ati dual video, 5.6" In dash, 13" lcd touch screen in back.
    96 gt conv. Mustang
  1. Designing a double-din case for 2003 WRX
    By Giuliano in forum General Hardware Discussion
    Last Post: 03-26-2004, 10:19 PM
  2. LCD in rear window
    By ryanerb in forum LCD/Display
    Last Post: 11-21-2003, 08:45 AM
  3. Using Small LCD Monitors with Digital Camera
    By darethehair in forum LCD/Display
    Last Post: 11-02-2003, 06:47 PM
  4. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 02:46 PM
  5. LCD Controller and DVD Decoder
    By berniejr in forum General Hardware Discussion
    Last Post: 03-08-2002, 10:23 PM
