Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: no windows shutdown options
  1. #11
    Jan 2003
    Ruston, LA
    Open device manager. What do you see here ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    FLAC djmickyg's Avatar
    Feb 2004
    ok this is making sence now..
    under computer in my device manager, i just have "standard PC"
    ok next questions.. where would i find this to install it??
    thanks heaps all of u's. ive got 2 pc's with the same problem.. and another one has it and ive never been able to understand why
  3. #13
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Quote Originally Posted by djmickyg
    Ugh...I was just trying to change a friend's motherboard and I stumbled on the fact that Windows XP is a ***** with APM.
    Correct me if I'm wrong, but if I remember right, once you install Windows XP, it isn't possible to change the power management (unless you reinstall). It has to do something with the fact that it is too deeply integrated into the OS.
    You have to make sure it is enabled in the BIOS before you install Windows, otherwise you'll get that "Standard" business.
  4. #14
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by frodobaggins
    Most PCs built in the last 5 years have this.
    Odd, just checked both the Shuttle MB I am using and the other computer near me which has a BioStar MB and neither of them have this option.
    Installed.
    -GPSSecure- - GPS Tracking
  5. #15
    Jan 2003
    Ruston, LA
    Quote Originally Posted by brady
    I bet it does. Look in your bios for APM or ACPI.
    They needed to be enabled when you installed windows.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #16
    Feb 2004
    well i been reading up on this..
    it is possible to do it after windows is installed but.. it involes alot of file hacking and all sorts of dangerous ****..
    what i had to do was reinstall windoes and when it says "press f6 to install some rad driver" u press F5. and another menu opens and u have to select what type of install u want and u must click the "acpi install" and it works sweet now
  1. windows shutdown script
    By marsjell in forum Software & Software Development
    Last Post: 06-12-2002, 01:24 PM
  2. windows shutdown
    By albysure in forum General Hardware Discussion
    Last Post: 02-27-2001, 09:23 AM
  3. Win2k quick shutdown options?
    By blkdragon6 in forum Software & Software Development
    Last Post: 11-14-2000, 01:34 PM
  4. shutdown Windows?
    By bass4040 in forum General Hardware Discussion
    Last Post: 03-20-2000, 11:00 PM
  5. windows shutdown
    By sulten in forum Software & Software Development
    Last Post: 03-03-2000, 04:51 AM
