Results 1 to 10 of 19
Thread: Cold Heat ????
    Constant Bitrate Lando's Avatar
    Apr 2002
    Cold Heat ????
    Any one ever use this?
    https://www.asseenontvnetwork.com/vc...ldheat/121315/
    My first soldering job and I was looking for a cordless begginer's iron.
    Aut cum scuto, aut in scuto
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I bought one, and promptly returned it. The tip is VERY fragile. It basically arcs across the contacts, so you have to have a large surface, it doesnt work well with small stuff. It doesnt have the oomph for the big stuff.
    Go buy a good cheap corded iron or a butane powered iron. I personally have a "Isotip" brand and it is Awesome! And it was only $20 + butane. Note, use GOOD butane, not the stuff for lighters. It will eventually clog the unit.
    here is a link
    2005 Ford Focus ST
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    These guys are in for a lot of cash. They are talking about material that can heat up in a matter of seconds. Their plans include heated car seats that could heat up instantly without having to wait on a cold morning. That's some interesting ****. And as for the soldering tool, I'm thinking about ordering it, sounds like something I would want to at least try.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Yeah, cold heat sucks. Wont heat up until you short it with two pieces of metal....and it DOES NOT get cold quick like on the commercial. Like a dumbass i burnt the hell out of my hand touching the tip 5 seconds after ATTEMPTING to solder something to no avail.
    PC Components:
    My work log
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Yeah I got one too after hearing some reviews that is was fantastic, but I couldn't get it to work right for the life of me. It would never heat up the solder right and I couldn't use it to consistently solder anything.
    Definitly stay far far away from this product.
    Also as a beginner, the last thing you want is a "beginner's" soldering iron. The cheap ones are much harder to work with. Soldering isn't hard once you learn the basics, but its harder then it looks. Your much better off spending $50 or so on a halfway decent soldering station that heats up good and is controllable. These also normally have more safety measures in them so you won't catch your house on fire as easily.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    May 2004
    NJ
    I thought it was good when I saw it at HomeDepot, WRONG! waste of money. Good old snake oil in 21 Century package.
    Jun 2004
    It works good for some projects, but I find myself using my corded 35 watt iron 30% of the time over the cold heat. It takes some getting used to, you can't use it like a conventional iron. I don't think I would use it on logic circuits or anything that could be fried by 3 volts. I was adding an LED for hard drive activity, and while soldering it under my two armed magnifying glass thingy, I kept seeing a blinding light.
    The cold heat tool was powering the LED.
    Low Bitrate Hopperhawk's Avatar
    Nov 2004
    USA
    Quote Originally Posted by Lando
    I bought this and returned it right away for a weller after finding out that it works by storing the 4 AA batteries power in capaciters and the shorting out the capaciters with the solder (Or material) it was HORRIBLE for electronic work and was even harder to 'tin' anythign as the solder doesnt accually stick to the non-metal tips (The metal is accually a connection in the tip and not the shaft.. so there is nothing for the solder to bind to)
    These are my findings and for anyone that DOES own it... Just dont try to touch the batteries after using it for 5 minutes.... They get SCREAMING hot. RETURN THE ******* MOTHERLESS POS!
    Centrafuse 3.1
    Garmin Mobile PC
    GPS, OBDII, Lilliput 629GL, Nightvision integrated video,
    Other fun stuff in works.
    Strange.... I really like mine. It works great... and I'm even modding Xbox's and PS2's with it (super small solder points). Done about 10 and have had 0 problems. I did buy their smaller tip though, which helps a lot.
    It does take a little getting used to, but once you do it works great. I haven't picked up my old soldering gun since I got it.
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Quote Originally Posted by gospeed.racer
    here is a link
    Have you used this on heavy wires-10-12 guage? I'm looking for something that can handle bigger stuff that my corded 10 watt doesn't do a very good job on.
    '03 Sierra Denali
  1. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 09:37 AM
  2. Cold and Heat?
    By raptorsoft2000 in forum Newbie
    Last Post: 10-30-2004, 10:00 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 09:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 08:18 AM
