Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 70
Thread: Reverse camera query: USB webcam or mini "spy" camera?
  1. #21
    Dec 2004
    Perth, Western Australia
    I have done quite a bit of testing on webcams and CCD type spy cams for work projects and one point no one has made yet is that CCD spy cams (especially black and white ones) have much better low light performance.
    We couldn't get comparable low light performance form a webcam until we spent approx AU$300 compared to a AU$50 black and white CCD(not CMOS).
    No this research was all done about a year ago so web cameras may have got better since. Just something to think about.
  2. #22
    Nov 2004
    I personally wouldn't use a web cam.. like mentioned before the majority of them have very slow responce...
  3. #23
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Who can write a program that will display a real image with an overlay of selectable weapons to virtually blow away the traffic?
    TruckinMP3
    Read the FAQ!
  4. #24
    Low Bitrate andyhardy's Avatar
    Mar 2004
    Bexhill, East Sussex, England
    The spycam receiver can be wired into a relay to switch on - if your TFT has auto switching on then perhaps it might automatically switch to reverse when the reversing light is on? (using the signal from the reverse gear switch at the selector).
    That way you can have it fully automated - although wiring in a switch would be good so you can keep an eye on the bloke behind you even when not reversing!
    Just a thought,
    Andy
    P.S. I have a front mounted bumper cam in my Fiesta - it's only a cheapo one at the moment but it was just to test it to see if it would get destroyed at high speed or perhaps leak with rain etc. I have taken one of the front spotlight bulbs out of teh unit, cut the back out to squeeze the webcam in and then removed the glass from the front and used some clear perspex sealed into the light unit using some bathroom silicon sealant.
    Unfortunately the car hasn't been running enough for me to test out the video recording side of it - but when it has been running it's really cool seeing the view from so low to the ground
    I'll post some videos up as soon as I get it all running properly although thinking of changing to one of the newer high frame rate webcams to replace it (should be easy - done the hardwork now)
    Cheers,
    Andy
  5. #25
    Constant Bitrate HoSS's Avatar
    Dec 2004
    black box
    It's something I was thinking about...
    The advantage of a webcam is that you could record.
    It would be great to have a 'black box' application that just records the last few minutes continuously.
    In the case of an accident etc, you could use this as evidence (unless it was your fault, then it gets mysteriously erased )
    Anyone want to write this app?
    HoSS
  6. #26
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I'm sure I have already seen that kind of software available. I t may have come free with a webcam I had.
  7. #27
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    I went the composite way, purely as the camera would be able to run without carPC switched on. Better night quality too.
    However, one bad point is that I cannot record anything from it, well, not unless I a) install a dvd/vcr recorder in the boot or b) feed it into usb as well and get software to record it all.
    However, I dont really think i would ever want to record a rear facing camera - not unless some t*at is tailgaiting me so close that I could get him, his car and his numberplate.
    Having said that the police wouldnt do anything about it anyway.
  8. #28
    Constant Bitrate SamDude's Avatar
    London (UK)
    Anyways...
    Good to see so much input and discussion from my thread, but there is a question that remains unanswered:
    Quote Originally Posted by SamDude
    How is the CCTV/composite camera powered?
    Can it be connected to an Opus/Carnetix PSU or is it directly connected to the battery?
    (This would mean constant power even when the car is not running...)
    Thankos Muchos!
  9. #29
    Dec 2004
    It could be powered however you like...
    If it is a USB cam it will need 5v, if composite probably 9 or 12V.
    I would avoid a direct connection to the car 12v (if it is a 12v cam)
    better to run it from a cleaner supply, PC psu or other regulated supply.
    HoSS
  10. #30
    London (UK)
    Thanks Hoss...
    How much power does a composite camera draw? (+/- for a USB webcam?)
    Are there any particular (wide angle) camera's which work well for the price?
    Any hanging around eBay?
    Thanks again.
  1. Displaying reverse camera on a carputer?
    By coachreed in forum LCD/Display
    Last Post: 04-22-2008, 05:47 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  3. Replies: 10
    Last Post: 12-20-2004, 12:15 PM
  4. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:21 PM
  5. USB webcam as reversing aid
    By RobIles in forum Media Engine
    Last Post: 06-19-2004, 03:50 AM
