I had the same problem with RX. I eventually gave up on it.
I am having problems with the sound from Radio Extreme. While playing the stations, the sound will drop the 10-15 sec, and then be loud again. I have tried different antenna adapters, but this sound level change does not correspond to any changes when plugging the antenna or relocation the antenna.
I tried both at home and in carputer, same problem. Did anyone have this issue with Radio Extreme or it is a Radiator issue? Any info would be greatly helpful
Thanks.
MikeH
Thats too bad. I wanted to have at least some kind of fm radio.
I know it sounds a bit far fetched but do you ahve the XP voice recognition stuff turned off and how is the radio connected to your Pc? Keep and eye on your volume control sliders (both rec and playback) while it is happening - just to try and eliminate possible causes.
its not the volume. It sounds like a reception problem but most likely the problem with the unit.
