May be you don't have enough power from your PSU ? Just guessing...
during the initial startup when the BIOS checks the RAM, it will freeze. It only does it if I have EITHER my GPS OR my Video Capture device, both USB. If I unplug both of those and boot, then it goes through fine all the way to Windows. Then I can plug them in and reboot and it works fine because the board only tests the RAM after it totally loses power, which means if I cut the power to the PSU then i have this problem again.
I checked the RAM with Memtest86 and came up with no problems. It only does it when I have either of those devices plugged in, but it ALWAYS does it if I have them plugged in--very consistent. Just like ryuandwings, it has been working fine since I got this thing back in April or May and just started yesterday. This system has been in development since last spring and I am supposed to ship it out to Canada NEXT WEEK. Murphy's law I suppose![]()
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
Car pc integration with ease
Car mediacenter
this is on the desk bench using a standard 300w PSU, so I dont think that's it. But I guess I could try another PSU I have lying around here.
I'M DEBT FREE!!
i'm pretty sure its a power problem as well
CarPC install is starting to come along again...
here's the thing: I have externally powered hubs that I can use, and the problem still exists. Using those hubs, the devices are not using any(?) power from the PSU so that shouldn't be a factor anymore?
I had suddenly remembered that I hooked up a full sized slot-load DVD drive at some point in the last 24 hrs, but removing that didnt have any effect.![]()
I'M DEBT FREE!!
Try asking this question over at www.abxzone.com they have a lot of smart people over there.
2009 Altima 2.5S CVT Dark Slate
Disable the memmory check in BIOS see what that does. Also Make sure the BIOS is latest up to date, this is of course if it really isnt a power issue.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
what brand mobo and cpu? are the devices usb 2.0?
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
its an epia m10k, the GPS is usb1.1 and the video capture is 2.0
I couldnt find anywhere in the bios where I could disable the memory check, because that would definitely fix my problem. Im gonna update the bios here in a minute so we'll see how that works out.
I'M DEBT FREE!!
Not to be repetative, but it does sound like a power issue. Did you try an alternate supply? Does the problem happen with any other combination of USB devices? Could one of your USB devices be defective and thus overdrawing the 5V rail? Does the problem happen no matter which USB ports you use on your m10k? Did you try another stick of RAM?
