Here you go http://www.xmfan.com/viewtopic.php?t=30627
Hello All. My XMDirect is on the way, and I was wondering if You guys could post wire diagrams of all the cables made. Also I wanted to know if there has been anything done with USB yet? Cause I have a crap load of Belkin Gold USB Cables.
1987 Pontiac Fiero GT
XPCarputer Coming Soon
[IIIIIII---] 70% Complete
XPC Model SN41G2V2
AMD AthlonXP 1800+
2× Mushkin 256MB DDR
Pioneer DVDRW
80GB 7200RPM UltraATA HD
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
Way too much info for me. I heard some things there about USB, But I didn't find any wire diagrams. Maybe I should just get a USB 2 Serial dual adaptor, so I can add some serial ports. My Shuttle only has one serial port. But it has 4 USB Ports and 2 FireWire ports. I'd really like to make a direct USB cable using my Belkin **** here.
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
I am not aware of an easier way to do it then making the serial cable and useing a usb adapter. check out this thread and i put pics up of my cable on my site under carputer -> xm in my sig. Then just use a serial to usb, no one in the thread seemed to have any issues with the usb.
Hope this helps
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
What he said.
Well, I found some USB-serial adaptors which were just wire harness's. No computer boards or anything. So what I was wanting to make is instead of a XM to Serial and use a Serial to USB ADAPTOR. Find out how to make my own Serial to USB Adaptor, and make a XM to USB Cable instead....
Looking at that info now.
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
they discussed it in that thread, and came to the conclusion that it was not feasible, but take a look I did not read that part throughly as I was not planning on doing the usb part.
My Install
Software:
CFiG v1
CarShell
StopWatch
Well, they said the Serial to USB adaptor works just fine. So I'd like to find out how to adapt the cable from XM to Serial to USB. Even if I have a buldge in the wire from whatever I need, thats ok. Just so that there is no other connections, its one wire, XM to USB with a Serial to USB adaptor inside the harness.
So pretty much what I need is working wire diagram for the XM to Serial cable, and a working Serial to USB adaptor diagram. Then I'm sure I can hack up a few cheap cables I have, build a working one, and then build a full out Belkin XM to USB Cable
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
The pins on the USB are as follows:Originally Posted by jcdillin
Pin No.______Name___Description
1___________VCC____+5voltage (max. 500mAmp)
2____________D-_____Data - (Input to computer)
3____________D+____Data + (Output from computer)
4___________GND____Ground for voltage
So with that in mind...couldn't I just use the GND, D- and D+ wires on the USB for the Pins 1, 2, and 3 on the other cable? I dunno, I'm sure I can make a full out harness for XMDirect -> USB if I can get the two diagrams of the XM Serial cable and Serial USB Adaptor.
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
I am realy curious ...
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
