Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Pc keeps freezing and powering off
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Sounds like your alternator isn't powerful enough.
  2. #12
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    get in the car - with pc going/car running
    How stable is that? Try for 5-10min
    Turn lights/heaters/ everything electrical on, and ditto
    If u manual - try to take off - using as low a rev's as possible (like just before stalling it).
    Ur voltage may be dropping out
  3. #13
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by nzKAOSnz
    Get a digital meter and measure the voltage coming out of the power supply under all conditions. If it's pretty steady, you can't completely rule out a voltage problem, but it would be a lot less likely. I had frequent freezes on my PC if the car was off. Turned out to be low voltage. You may have the same problem in reverse.
    Want to:
  4. #14
    Dec 2004
    Nottingham, UK
    The voltages are fine and ive had the car running for 20 minites plus and the pc has been fine. Ive shook the pc about (not to hard ) but that didnt do anything.. only seems to cut out or power off when i move the car.. could it be something to do with the EARTH?
  5. #15
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Still sounds like summit loose to me and my best bet would be a pic card or the CPU. Check and double check all your connections, including closing all molex connectors with a small screwdriver as they open out. With PCI cards try puching the part furtherest away from the back panel and see if it rocks in, also try taking the screws out, puching them back in and then when you put the screws in check to see if the car moves out again - you could have a slightly warped case which will make the cards unstable and prone to moving when you drive.
    Good luck
    Andy
  6. #16
    Mar 2004
    Bristol
    Quote Originally Posted by lindleyalex
    try twisting the case and pushing the panels.
