Results 1 to 6 of 6
Thread: carputer plunge #2
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    Cool carputer plunge #2
    So my epia m10000 decided to stop outputting any video signal after updating the bios (per instructions on via's site)
    thinking it was my 8" lilli, i tore it apart and tried reseating the ribbon cables, tearing one pretty good in the process
    seeing how im takin a 1000 mile road trip next week, i decided to upgrade and fedex 2-day the following items:
    -insight p4 itx mobo
    -p4 2.8ghz (no hyperthreading, tho the mobo supports it )
    -lexar high performance 2gb compact flash (keeping 80gb hard drive to store music till i buy the creative nomad jukebox zen xtra 60gb)
    -epia compact flash to ide adapter
    -pw-200 dc-dc power supply
    -replacement 30pin ribbon cable from digikey.com
    -destinator 3 30-day trial cd
    anyone have any experience with that p4 board? cant find too much info on the forums here... would like to know if i have to buy that ATI 128mb pci video card for 60 bucks i found somewhere (looking to have dazzling fullscreen vis goin)
    im assuming its all gonna work when i throw it together...
    I'll be installing all this in my old NES case, gonna cut a hole in the top for the cpu fan, cut out the back for the mobo ports, wire up the power & reset buttons, and mount a rectangular usb hub behind the cartridge door This should be a step up from the 8x16 piece of plywood i had been using for a "case".
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Quote Originally Posted by therussman2002
    Wow, I am doing just about same thing.
    My m10000 stop working and I could not figure out, so I order P4 mini-ITX board and P4 2.4ghz (just like you no HT, but board suppots it).
    I just got them in mail today, so I haven't done anything yet. But looking like I am going to have a little sleep tonight.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You should order an inverter as well. That PW-200 will not do anything to that setup.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2004
    Milwaukee, WI
    eh mini-box.com claimed the pw200 worked with that board & a p4 up to 3.06ghz
    i still have my 90w opus, wonder if i can use both somehow (w/o opus i gotta hit a button somewhere to turn the darned thing on everytime)
    FLAC alti's Avatar
    NY
    200 watt for a P4? thats not a lot although i beleive your CPU is a Northwood which would put it at about 65 watts max which is less then the 100 watts that the other p4's pull. Are you useing a video card or onboard? That is going to be real close.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Mar 2004
    Milwaukee, WI
    im usin onboard, got a pci audigy2zs though... and i plan on runnin a 3.5" hd on it for a short while
    would hope to run the lilli off of it, we'll see what happens
    does anything bad happen to the hardware if its low on power?
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
